12-31-2015 05:37
12-31-2015 05:37
12-31-2015 08:29 - edited 12-31-2015 08:30
Hi @LyndonChao
Have moved your post from the Charge HR to the Third-Party Integrations section to increase the chance of getting a solution.
Wishing a Happy & Healthy New Year
Best Answer12-31-2015 09:28
12-31-2015 09:28
Best Answer01-02-2016 16:14
01-02-2016 16:14
I'm having the same issue? what was the fix for you?
Best Answer01-03-2016 05:35
01-03-2016 05:35
Hi all - I am having the same issue also - looks like a common problem ?? I have separately e-mailed FitBit.
Best Answer01-03-2016 17:32
01-03-2016 17:32
Best Answer01-05-2016 08:18
01-05-2016 08:18
Please read below, I added ALL CAPS to what I added to Fitbits suggested remedy as this is what worked for me and I used existing email and did not lose any data!
For us to help you with this, kindly disconnect and reconnect FitStar and Fitbit by going to app.fitstar.com and logging into your account.
To relink the account you created by registering with Fitbit and link it to your main account, complete these steps:
1. Go to app.fitstar.com and log in to your FitStar account with the option to login with Fitbit.
2. Click the menu icon in the top right corner, and choose Settings.
3. Click "Email and Password" and add an email address and password to your account. [OR IF YOU ALREADY HAVE AN EMAIL ADDRESS ENTERED JUST LEAVE IT] Please note that the email address you use must be different from any other email address you’ve used for an existing FitStar account. [NOT TRUE IN MY CASE AS I ONLY HAVE ONE EMAIL ADDRESS AND I HAD ALREADY PREVIOUSLY ENTERED IT WHEN LOGGING IN THROUGH FITBIT AND LEFT THIS EMAIL ADDRESS HERE AND JUST DID ALL THE ABOVE AND THEN LOGGED IN THROUGH FITSTAR INSTEAD OF THROUGH FITBIT. IT DID NOT SEEM TO BE IMMEDIATE IN WORKING; HOWEVER I KNOW THE VERY NEXT EVENING I DID 4 WORKOUTS AND ALL OF THEM SYNCED AND LOGGED TO FITBIT.]
4. Next, click "Services" and disconnect Fitbit.
In addition to that, please be advise that disconnecting and reconnecting will not sync their past history but should insure that any future sessions sync correctly. [THIS IS NOT TRUE EITHER; IF YOU KEEP YOUR EXISTING EMAIL ADDRESS AS I DID YOU KEEP ALL YOUR EXISTING DATA!!! YAY!!! AWESOME!!!]
You'll now be able to link your main FitStar account to your Fitbit. Let us know if you have any further questions. [THANK YOU FITSTAR FOR STICKING WITH ME ON THIS ISSUE!]
Best Answer01-13-2016 09:05 - edited 01-13-2016 09:06
I tried this and I still don't have my past workouts showing on Fitbit dashboard.... So far I haven't been able to sync ANYTHING between the two services. I contacted fitbit and fitstar help and nothing has worked yet. Any help would be greatly appreciated because this is really frusturating.
Best Answer01-25-2016 07:56
01-25-2016 07:56
Best Answer01-27-2016 07:25
01-27-2016 07:25
Me too, I've followed all the tips and tricks from posts as well as from Fitbit/Fitstar, and still not syncing.
Best Answer01-29-2016 07:20
01-29-2016 07:20
Hi - I was having a similar issue with Fitstar but mine was due to lack of minutes exercised!
After finishing a half hour aerobic exercise (T25) I would rest and then complete my routine by carring out one of the daily FitStar plans.
The issue for me was the FitStar plan only ran for 12 minutes and I had my settings to only recognise activity after 15 minutes. By changing this down to 10 before starting that exercise, the FitStar exercises have been automatically recorded going forward.
In the App these settings are found under Account / Goals / Exercise
Not sure if that helps but I thought I'd share what my solution was.
