I've recently linked my Fitbit account to Runkeeper, but it only synced activites newer than one month to Runkeeper. I've been using fitbit for 3+ years, so it would be great to have all activities synced. Is this possible?
I've tried disconnectiong and reconnincting a few times to no avail.
I have not yet transferred to google account since it seems I would lose all my firends on fitbit. I have started a download of my data since that option is still available to me, but not sure if I can use that.
@Axelv It should work as you described. So I have no solution.
On the other hand I personally wouldn't make a synchronisation between app that start before the start of allowance.
When you transfer your account you should verify that your connections are still running. Just to be sure. I can't recall having problems with that.
And yes, you loose connection with the friends that are not transferred.
