12-16-2015 22:30 - last edited on 12-23-2015 06:50 by Mcore
Moto Body a couple days ago announced data sharing with third party apps such as Fitbit, Strava, Google Fit, etc. I've authorized Moto Body to partner with Fitbit.
How do I sync the data between Moto Body and FItbit? Also, does this mean Fitbit's data will transfer over to Moto Body or is it only from Moto Body into Fitbit?
Very confusing - Any help would be appreciated.
Moderator edit: Updated subject for clarity.
03-11-2016 06:15
03-11-2016 06:15
What does this mean? Are you saying that the Moto 360 needs to have wifi turned on so it can sync the data to fitbit?
03-11-2016 06:27
03-11-2016 06:27
@Rachyalexis wrote:Just to clarify, does this mean that it SHOULD work for a MOTO 360 Moto body app?
Nope, I was told that it will work only for MOTO SPORT version by motorola on the ticket I raised with them.
03-11-2016 06:56
03-11-2016 06:56
Everyone doesn't seem to know what's going on because I raised a ticket with them too and the girl told me that it should technically work if I have the Moto body app
03-11-2016 06:59
03-11-2016 06:59
@Rachyalexis wrote:Everyone doesn't seem to know what's going on because I raised a ticket with them too and the girl told me that it should technically work if I have the Moto body app
@Rachyalexis - Could be. If I raise another ticket I might get another answer as well. I have provided my watch reference number so they could find out model, etc.
I only can live in a hope that one day the data integration will work.
03-15-2016 18:14 - edited 03-15-2016 18:16
Recent chat with Motorola. This is just plain sad. A feature that doesn't work. Fitbit? Any response to this hand-off?
03-17-2016 07:08
03-17-2016 07:08
I contacted Motorola about this as well and their support directed me to email their play store app team ((playstor@motorola.com)and no the e is not supposed to be there).......to which I have not received any kind of response other than the auto generated email they send. Maybe hitting them with some more emails about this issue might get their attention? Worth a shot if nothing else.
03-22-2016 09:59
03-22-2016 09:59
Hey Ferdin, the "solution" to this issue is not a solution. it should not be marked as a solution. Gives false hope/data.
06-07-2016 09:24
06-07-2016 09:24
It is very clear to me that Fitbit locks out updates if you haven't synced your fitbit device recently. I stopped wearing mine because I can't stand wearing my Moto 360 and my fitbit flex at the same time and it even blocks me from entering steps manually now. Fitbit (even though my account clearly synced 3 devices over the years) doesn't care that you've already purchased their product; they want you to continue wearing it as advertisement.
06-21-2016 23:43 - edited 06-21-2016 23:58
Motobody has only one activity in the watch Motobody / Run / Indoors / Time,distance etc.,
If you start this activity, then the Motobody lists this activity in the Phone as Run with the all the details.
This data (like distance, steps, activity duration, calories) get updataed automatically in the Fitbit application if if you have authorised.
The other data like steps, heart activity, heart beat records do not get updated automatically in fitbit. Indirectly, you can add manually activity duration and distance to match steps count in Motorala dashbord in fitbit
I want try out Motobody ---> Google fit ---> Fitbit to get all data in fitbit
@Gnans wrote:Raised a case with MOTOROLA and been said the data sync will happen ONLY for MOTO 360 version despite the data is shown on the mobile/android device.
Anyone with MOTO SPORT, try contacting Motorola for support on twitter.
06-22-2016 08:22
06-22-2016 08:22
So, I can get the data to sync, the thing is, Fitbit will NOT allow it to update to your total steps/comparison with friends. They told me that this is a built-in function that requires you to only use your Fitbit device when competing with your friends.
Bottom line is, it does sync, but you have to go look for your records on Fitbit and your total weekly steps and friends will never see them and you can't compare them to your friends on your dashboard. This is from Fitbit support.
06-22-2016 10:29
06-22-2016 10:29
I can confirm that this is the case.
I use FitnessSyncer (great site btw) to sync my Google Fit steps to Fitbit. I have a Fitbit account, but haven't worn a Fitbit device in many months. I have my phone and android wear device syncing steps to Google Fit.
FitnessSyncer does a nightly sync pushing my Google Fit data into my Fitbit account. The steps show up in Fitbit under https://www.fitbit.com/activities, but no step information appears on my dashboard (neither in the website nor the app) and it does not show my steps relative to my friends.
It appears that your step information do get to Fitbit, but you can't view those steps in the Dashboard or compare with friends. You need an actual Fitbit device to do that.
Might be possible to simply sync a Fitbit that you don't really wear, to trick the site into thinking you're using it. Then it might just "turn on" the full step tracking info and use the steps that were logged via Google Fit/Moto Body.
06-22-2016 11:54
06-22-2016 11:54
I tried that. Doesn't work. Will only report steps directly from a Fitbit against your friends. I synced my Flex and tried and only the few steps on my Flex went up against my friends and not the thousands on my watch.
06-22-2016 11:56
06-22-2016 11:56
06-26-2016 09:18
06-26-2016 09:18
Thank you kindly for sharing!
07-25-2016 21:56
07-25-2016 21:56
This is super discouraging. I switched form Nike Fuel Band because the Fitbit seemed more friendly for sharing, turns out this is not the case. I lost yet another fitbit and was hoping to use my moto 360 for a while to keep up my steps while I decided what to do about getting a new one.
Maybe it's time to just switch to Google fit.
07-28-2016 11:38
07-28-2016 11:38
Unfortunately, there's not much social sharing. Any of the apps are great if you're doing it to track your own progress, but it takes out some of the gamification of the steps when you don't have a running leaderboard. I eventually got over it and just use MotoBody (I love their weekly summary email).
