I use Fitbit Surge to record activities and then sync with Weight Watchers. I forgot to turn the Fitbit off after Spin class so it's recorded too many Fitpoints. how do i edit it to override this and record the right number of points?
Best AnswerOn Fitbits side you would need to delete the event and manually log it.
However once the points have transferred to WW, you will need to do the editing of the WW points through your WW account.
That is why i moved your post to the third party forum.
You could help yourself by editing the title to "Editing Weight Watchers points", since this is the subject.
Best AnswerFrom the Fitbit app swipe right to left and select Delete, or go into the activity and hit ... in the top right and delete from there.
