I have been using a excercise app called fiton that is able to connect to fitbit if I set it up on fitbit (that's what it says) yet I can't find any settings to add app permissions. Can someone assist me with this please
You originally posted under the Sense 2 section but you mention Charge 2 in your post. Regardless...
The implementation done by FitON (wonderful app and service by the way, what Fitbit Coach Premium isn't) is a bit strange.
Differently than other similar services the exercises performed on FitOn are not linked with Fitbit so you won't find the exercises that you have done in FitOn also on Fitbit (differently than what done with Google Fit for example)
What FitOn did was to write an app for Fitbit smartwatches that reads the heart rate and allows to show it while following the exercise on FitOn. By the way this is also only possible if you have the Premium membership of FitOn.
Finally, and this might be the missing piece of information, the mentioned app is not available for Sense 2 and Versa 4 beacause Fitbit doesn't consider its greatest products no longer smartwatches but just trackers with a big display and therefore not allowing the developement of apps.
Best AnswerYou originally posted under the Sense 2 section but you mention Charge 2 in your post. Regardless...
