04-01-2020 04:06
04-01-2020 04:06
I've connected both via the compatible app section on both apps but still can't seem to see the data from fitness pal pulled across to fitbit?
Best Answer04-02-2020 06:51 - edited 04-08-2020 09:04
Then I think you need to open a chat with My Fitness Pal support
Fitbit allows it but the rest needs to come from them
Wendy | CA | Moto G6 Android
04-02-2020 15:58
04-02-2020 15:58
For what it's worth, I followed all the appropriate steps. I saw a "fitbit step adjustment" pop up for one day on MyFitnessPal, but it showed no steps, and then it didn't show up after that. I tried again with the same result. It seems the integration is broken.
It's too bad too because MFP has way better food data.
Best Answer04-08-2020 08:59
04-08-2020 08:59
MFP is responsable for their connection with Fitbit. I suggest following @WendyB'a suggestion and contact MFP.
