10-06-2021
20:52
13:17
BraulioFitbit
10-06-2021
20:52
13:17
BraulioFitbit
WW last synced with Fitbit app in 2016. How do I remove and reset - how do I add WW back to applications?
10-11-2021 13:16
10-11-2021 13:16
Welcome to the Fitbit Community, @jomamah1.
Thanks for the details shared. To remove the connection between Fitbit and WW you need login to your online dashboard and clock on the gear icon located on the top right corner > Settings > Applications. To reconnect both accounts you can follow the instructions from this post.
See you around.
10-11-2021 13:16
10-11-2021 13:16
See you around.
