12-28-2018 03:55
12-28-2018 03:55
Hi are there any further updates on when an app compatible with the Dexcom g6 app will be available for the fit bit versa. I bought mine on the basis that Fitbit said this would be developed by the end of 2018.
07-15-2019 07:56
07-15-2019 07:56
After installing the app the watch displayed my dexcom results after a few seconds. Now it is hit or miss if it will display it at all. All limits are in place, I dis-invited and re-invited myself, had the share app on, and everything else I could think of.
Also, does it need a WiFi connection to receive the information? The problem I am having witth getting the data is when I am home, but I wondered if it did require a connection.
07-20-2019 09:53
07-20-2019 09:53
Been trying to figure this out all morning. Can’t seem to get my bg numbers to show up. Ive entered my dexcom info in the Fitbit app, set my min and max, added the share app. Nothing seems to help. Any advice?
08-10-2019 11:32
08-10-2019 11:32
Sorry - I don't understand. I'm the worst with tech. I got the watch face on my Fitbit Ionic, but it has no info. I went into the Dexcom app on my phone and turned sharing on. I don't have followers. Do I need them?
You said you use your login (username) and PW that you use with Dexcom. But where do you use this login and PW? Where do you enter it?
Thanks!
08-17-2019 05:28
08-17-2019 05:28
Is the software compatible with the versa lite?
08-17-2019 06:50 - last edited on 10-09-2019 12:30 by LiliyaFitbit
Hello,
If you all have any questions, please email us.
08-22-2019 09:00
08-22-2019 09:00
Got a note from a watch face company and baught their Dexcom pack of faces. Not happy to have to buy something I was assured came with the Versa!
08-26-2019 22:21
08-26-2019 22:21
I'm having the same issue. Can't figure out what I'm doing wrong. Share is on. Username and pw entered correctly. It worked for a minute or too, but then stopped.
08-29-2019 18:58
08-29-2019 18:58
Is this watchface working with versa right now?
08-29-2019 19:00
08-29-2019 19:00
08-30-2019 09:00
08-30-2019 09:00
08-30-2019 10:19
08-30-2019 10:19
For me, it doesn't work good enough.
I have used the watch face which in itself is well made, but there are so much issues with the watch face syncing that I returned the Versa I purchased.
At some points, it didn't sync for many hours, and showed a different value than my phone, hence it could not be trusted.
The fitbit versa itself is good, but I will wait until an official integration arrives.
09-03-2019 11:57
09-03-2019 11:57
Will this dexcom app work with the new Fitbit Versa 2? Thanks, Pam
09-04-2019 08:22
09-04-2019 08:22
I baught the DeX watch faces & want to try one of the others in the package. Do I have to uninstall to switch between them?
10-07-2019 20:33
10-07-2019 20:33
Ok, realtime CGM worked and now watchface says CLOCK ERROR GO TO FITBIT APP AND TRY ANOTHER FACE. I BAUGHT YOURS & LIKED IT SO CONTACT ME & FIX IT.
10-24-2019 11:08 - edited 05-08-2020 22:47
I was just checking to see if this thread was still alive. I'm the author of the Sentinel series of clockfaces. We have a facebook group for those who want access to the latest experimental versions, and we currently have 2 versions in the public gallery: Sentinel and Sentinel One. And all of them are free and currently support dexcom share, nightscout, xdrip+, and SpikeApp as data sources.
FB Group: https://www.facebook.com/groups/3185325128159614/
thanks.
Sentinel PRO (new, and Free):
11-20-2019 07:34
11-20-2019 07:34
What is your email address? I have some questions
Thank you
Michelle
11-25-2019 12:00
11-25-2019 12:00
We have a Facebook group for the Sentinel clockfaces. Sentinel FB group
12-09-2019 16:11
12-09-2019 16:11
What Fitbit are the dexcom watch faces compatible with?
12-09-2019 16:54
12-09-2019 16:54
Visit the Sentinel Facebook group page for details.
12-10-2019 07:25
12-10-2019 07:25
Our dexcom faces are available for Fitbit Ionic, Versa, Versa lite, & Versa 2.
We would really appreciate it if everyone could go into their Fitbit apps and give our Dexcom products a star rating (Preferably 5 stars) 🙂
