12-28-2018 03:55
12-28-2018 03:55
Hi are there any further updates on when an app compatible with the Dexcom g6 app will be available for the fit bit versa. I bought mine on the basis that Fitbit said this would be developed by the end of 2018.
Best Answer12-10-2019 14:23
12-10-2019 14:23
I bought the versa 2. downloaded the app and the watchface put my dexcom info in but when i go to pay it says put in the 6 digit code on the watch but I dont have one. please help.
Best Answer12-12-2019 18:46
12-12-2019 18:46
Best Answer12-12-2019 19:08
12-12-2019 19:08
You can find it here:
https://k-pay.io/bundle/?bundle=381&check=f0478956-1c51-11ea-9fdf-066beb581631
Best Answer12-14-2019 19:28
12-14-2019 19:28
It doesn’t work.
Best Answer12-15-2019 19:12
12-15-2019 19:12
Downloaded the graph face. The instructions say to purchase to activate. When I click on the kpay link is only says to enter code from Fitbit. There's no code showing on the Fitbit and now where to pay first to get a code. Very frustrating. Need better instructions for using.
Best Answer12-15-2019 20:01
12-15-2019 20:01
You don't have to pay money for a CGM Fitbit clockface. There are options. The Sentinel clockfaces are FREE. The Glance clockface is FREE. There are a few others that are FREE. There are Facebook groups, fairly large communities, that provide support and updates. Google it. Try it. Go with what works.
Best Answer12-15-2019 20:22
12-15-2019 20:22
Please send us an email at thehunterwatchco@gmail.com
Thanks
Best Answer12-16-2019 09:27
12-16-2019 09:27
Best Answer12-26-2019 17:52
12-26-2019 17:52
I purchased the all faces forever and still have not received my email to download. What do I need to do?
Best Answer12-26-2019 18:01
12-26-2019 18:01
Best Answer12-26-2019 18:02
12-26-2019 18:02
You can download the Dexcom faces from here: https://hunterwatchco.com/category/dexcom/
Best Answer12-26-2019 19:31
12-26-2019 19:31
Best Answer12-27-2019 00:43
12-27-2019 00:43
12-31-2019 20:57
12-31-2019 20:57
Best Answer01-06-2020 07:37
01-06-2020 07:37
I have installed, uninstalled, changed my user name and password... I feel like I have done everything possible and still can't get the graph or watch face to work
Best Answer01-06-2020 08:01
01-06-2020 08:01
Best Answer01-06-2020 08:02
01-06-2020 08:02
Make sure you have Dexcom share setup with the account you are using.
Best Answer01-09-2020 10:01
01-09-2020 10:01
Best Answer01-09-2020 10:07
01-09-2020 10:07
Best Answer01-09-2020 10:10
01-09-2020 10:10
If you shoot us an email, we can help you get your product working. We actually worked with Glance to get our product built and running.
But definitely shoot us an email and we can get you running.
