11-06-2018 03:36
11-06-2018 03:36
Hi, is there a way to sync interval training to strava? I have set my GPS on as I do it for sprint training.
Best Answer11-06-2018 05:35
11-06-2018 05:35
No I dont think there is. As far as I am aware only run is synced to Strava automatically
Helen | Western Australia
11-06-2018 10:33
11-06-2018 10:33
@cgray2017 and @NellyG bike rides also sync
It might be possible to manually transfer the data following @LanuzaFitbit's instructions in this post.
11-06-2018 20:00
11-06-2018 20:00
@Rich_Laue Thanks. Didnt realise bike did too!
11-07-2018 12:53
11-07-2018 12:53
Hello @cgray2017, it's good to see you around in the forums.
Thank you for your inquiry regarding the interval training with Strava, I actually haven't seen this activity being transferred to Strava, but I do know that runs and rides tracked with Strava will contribute to your all-day Fitbit stats.
The following types of activities are the ones that would not sync to Strava:
However, I do recommend that you try the steps mentioned by @Rich_Laue previously to transfer data. You can find more information here as well.
I hope this helps.
Best Answer11-01-2019 08:20
11-01-2019 08:20
It would be great if you implemented syncing of interval timer to Strava.
04-12-2020 18:19
04-12-2020 18:19
Is this still not automatic, nor even possible?
Now seeing an error if I even try to download a TCX file to try to upload it to Strava:
Best Answer04-12-2020 20:04
04-12-2020 20:04
@evillama if your reffering to intrrvals, your right in that this is not possible.
Best Answer04-12-2020 20:10
04-12-2020 20:10
Thanks.
Can someone at Fitbit confirm if this is in the backlog?
I'm trying to convince friends to buy these devices but they don't just run, they lift weights, do yoga, etc. and want a device that will upload these activities to Strava (like Garmin does).
Best Answer04-12-2020 21:05
04-12-2020 21:05
I don't know what Garmin uploads to Strava, are whether Garmin or Fitbit owns the API. Does Garmin upload to Strava, or does Strava download from Garmin.
When it comes to Fitbit, Fitbit uploads to Strava, based on an agreement between Fitbit and Strava.
Best Answer04-12-2020 21:08
04-12-2020 21:08
Right...so regardless of how Garmin does it...Fitbit needs to update their agreement with Strava to improve the service.
Best Answer04-12-2020 21:19
04-12-2020 21:19
Have you added your vote?
04-12-2020 21:27
04-12-2020 21:27
Best Answer04-13-2020 04:37
04-13-2020 04:37
This feature is between Strava and Fitbit, also Fitbit never promised that every suggestion would be implemented or possible.
Best Answer04-13-2020 04:45
04-13-2020 04:45
@evillama @Rich_Laue Fitbit uses exactly the same API to sync with Strava as competitors (and anyone who wants to sync any 3rdparty app with Strava, it's really not rocket science). For some reason, Fitbit decided not to support non-GPS activities. I really don't know why because Polar, Garmin or Suunto upload any kind of activities to Strava. My guess is that Fitbit cannot do that because there is nothing to upload (no TCX file produced for non-GPS activities) while competitors produce TCX or FIT files regardless, whether GPS is on or off. It's just a limitation created artificially by Fitbit and I don't think they are looking into changing that.
Best Answer04-13-2020 05:40
04-13-2020 05:40
Best Answer04-13-2020 05:50
04-13-2020 05:50
It's an old Fitbit issue. The interval run doesn't seem to produce a TCX file( the bug that the message keeps saying that Fitbit is looking into it since 2018- doesn't seem to be fixed, despite looking into it for 2 nearly years). There is nothing to publish to Strava.
Best Answer04-13-2020 07:43
04-13-2020 07:43
Hi @t.parker vocab you I post a link to the thread?
I checked the known bugs and don't see intervals mentioned.
Both Fitbit and Strava say intervals will not be transferred.
Best Answer04-13-2020 08:44
04-13-2020 08:44
@Rich_Laue can you download TCX files from the interval workout when GPS is on? I remember seeing the banner about the issue when trying to download it. Maybe it has been fixed, I am not able to check that. Still, it is more problem of Fitbit than Strava. Strava cannot recognize intervals from splits - that's true. Yet it may show workouts with such:
This is from my interval run synced with different watch into Strava. 0.2km are rests (walk), 3 intervals based on distance, distance and time. Strava can't show details but can take data and show anything. It is Fitbit not sending anything to Strava. But If Fitbit says it cannot be done, then the only option is using different device of which manufacturer doesn't see such problem.
Best Answer04-13-2020 10:34
04-13-2020 10:34
@Rich_Laue the issue is still there:
Just tried to export TCX, see the same error as on a day of doing this workout (almost a year ago!). I don't know what list of known issues you were looking at but maybe this issue should be known, too 😉 After all, Fitbit is "looking into it".
With Strava, you can upload activities manually as long as you can provide TCX or FIT files. Even if Fitbit/Strava sync is not implemented properly, the user could upload the workout manually if only not this bug.
@evillama can you check if you see the same pink banner when you try to download TCX file? If TCX isn't generated, there will be no possibility of syncing with Strava.
