01-28-2019
15:36
05:18
AndreaFitbit
01-28-2019
15:36
05:18
AndreaFitbit
Love my Fitbit. Love my Freestyle Libre Flash Continuous Glucose Monitor.
Is there a way to synch the data that comes out of both devices? Ideally to submit as an integrated report for either self-use or use by a physician in planning diabetes care.
I think I know that Fitbit's parent company is investing in a CGM that can be used with Fitbit by everyone, without a prescription, or need for a primary care physician, but, in the meantime, the Freestyle Libre is already here.
Thanks for considering.
Moderator edit: Updated subject for clarity.
Best Answer01-29-2019 04:53
01-29-2019 04:53
Welcome to the Forums @owene700.
Thanks sharing your suggestions on the matter.
Maybe you could post about in our Feature Suggestions board. That way other users can comment and vote on your idea to show that they'd like to see it implemented. Be sure to read the FAQ to better understand how that board works.
Let me know if you have any further questions.
03-15-2019 09:16
03-15-2019 09:16
Hey there,
I have created a watch face that works with the Libre CGM reader. It uses the BluCon credentials.
You just have to enter in your email, password, and full name that are tied to your BluCon account.
Here is the link to the watch face: https://gam.fitbit.com/gallery/clock/91932266-5baa-4afc-915d-c057980fd56b
Post back here any issues you may have and we will get it taken care of!
04-01-2019 18:30
04-01-2019 18:30
Is there a way to make this compatible with the Fitbit Charge 3?
Best Answer04-01-2019 18:54
04-01-2019 18:54
Unfortunately not. Fitbit only lets us develop for Ionic and Versa
Best Answer09-10-2019 11:52
09-10-2019 11:52
I have questions, I am picking up my freestyle libre tomorrow and plan on getting the versa 2 in a week or so. When it comes out on 9/15. Now I know I can use my phone using the NFC to read the sensor to the app. Do I need the additional devices or is there a way to link that?
10-31-2019 05:44
10-31-2019 05:44
Is there any freestyle Libre system that has been developed that is compatible with the Fitbit Blaze?
01-17-2020 07:09
01-17-2020 07:09
This will link to my libre and show the reading on my watch? Or how does this work?
02-13-2020 07:44
02-13-2020 07:44
I want to get this clock face but it doesn't have the heart rate on it. Would be a ay for you to make that an option?
Best Answer02-17-2020 11:57
02-17-2020 11:57
Hi there,
I just came across this thread and am looking to integrate my Freestyle Libre with my fitbit. I'm using android apps. I'm not familiar with BluCon - I didn't have to set up that as part of using the Libre. Do you have detailed instructions on how to use your watch face and get it working with the Libre?
Much appreciated!
-Amy
02-20-2020 12:47
02-20-2020 12:47
Hello ahunter,
I have a fitbit versa 2 and was wondering how much is the charge for the watch face I use for it to use my Libre?
Regards,
Kaye Williams
Best Answer03-25-2020 04:09
03-25-2020 04:09
I only get "no data". I am using blucon version 3.3.6 beta.
Best Answer09-01-2020 16:55
09-01-2020 16:55
Can't seem to find your app. Is there a different name?
10-05-2020 16:57
10-05-2020 16:57
I have the same problem. Freestyle libre is just if not more popular than Dexcom so I don't understand why freestyle libre doesn't have it available..
10-05-2020 18:22
10-05-2020 18:22
Blucon is a very raw and unstable system and application. I worked diligently and exceptionally cordial with their support team. They couldn't fix the problems toward the end of the device life. Even tho I requested a replacement within the warranty period, they would not respond to me anymore. My respect and trust died too.
05-21-2021 05:17
05-21-2021 05:17
Hi,
Tried to install and can't locate it in the Fitbit gallery - possible to add category, etc.? Thank you!
Best Answer07-01-2021 14:50
07-01-2021 14:50
I’m in the trial for the Levels Health app which syncs with the Freestyle Libre CGM. It doesn’t integrate with Fitbit Versa but if we all send requests for info and suggest they work on an integration maybe they would consider it. This is their invitation link: https://www.levelshealth.com/join?partner=JKUHQSUC
07-01-2021 17:57
07-01-2021 17:57
That would be very helpful indeed!!!!
04-15-2022 06:52
04-15-2022 06:52
Will this sync every minute of my glucose readings to the Fitbit "blood glucose" log? Or do i have to type it in manually?
This feature seems to be worth it if it works automatically.
Thanks.
04-15-2022 06:54
04-15-2022 06:54
