07-22-2015 10:34
07-22-2015 10:34
Are you NOT supposed to log your excersise in My Fitness Pal manually when you start the activity timer on the Fit Bit? Or does that double the calories burned? Thanks!
Best Answer07-22-2015 11:41
07-22-2015 11:41
I do log with MFP after activating my timer. I just use the timer to track the duration. So far, I haven't had any issues with double-counting. The MFP entry seems to just overwrite the activity timer time.
MakMak | Community Council
