Lumosity and Fit Bit - how to link
ANSWERED
On the fitbit third party page it says it syncs with Lumosity - I have checked both sites - I cannot see how to link them - help! How do I link them?
1 BEST ANSWER
Accepted Solutions
11 REPLIES 11
I can't speak for Lumosity specifically, but generally, you have to link to Fitbit from the other app/website. For example, I use myfitnesspal and from within their app or website there is a link to "apps," where you can add other compatible apps/services.
MakMak | Community Council
Hi @ConnieP and @MakMak. Good to see you both around! 🙂
I'd just like to add that you can check this page which is specifically for the integration with Lumosity and click on the "Learn More" button at the top right corner and this will take you to Lumosity's website for you to be able to link your Fitbit account.
Hope this helps and let us know if you need anything else!
Ferdin | Community Moderator, Fitbit
@FerdinandFitbit, unfortunately, those learn more links aren't very helpful, since they just take you to the main page of the connecting website...
My PC doesn't have Flash installed and since Lumosity seems to work with Flash, I thought that was the problem  but it seems it's not that then. Thanks for pointing that out @MakMak.
In that case @ConnieP, I'd suggest following MakMak's advice above or maybe getting in touch with Lumosity directly for them to guide you through the process of linking both accounts since it has to be done from Lumosity.
I contacted lumosity and their reply is that you can only link if you have a premium (paid) lumosity subscription. If you do then I'd suggest contacting them - they replied to me within a day
Thanks for jumping in and helping out @melvah@ConnieP, you might want to take a look at melvah's advise.
Hope you all have a happy new year's eve and a happy 2016! 🙂
Finally found the link!
http://www.lumosity.com/fitbit
Thank you!!
It says I need to buy the premium version
@Sambow, Lumosity is a premium service, it's not offered at any level for free, with the exception of the benchmarking it does when you sign up.
Not strictly true, as you can "workout" with 3 tests every day using the Lumosity app. I've been a free member for a few years now.
