Hello folks
I am new to FitBit and have ordered my charge 3 yesterday.
I tried to setup the FitBit App in Combination with MFP, but I got some problems synching them.
If I record a meal in MFP it takes a few minutes to sync to FitBit (I guess I can live with that...)
But If I record an excercise oder water on MFP, it does not synch to FitBit (neighter does it work vise versa...). This is very annoying.
I have seen this problem many times online, but did not find a solution that worked for me... and yes, I have tried to unpair and reconnect MFP with Fitbit quite a few times now...
Anyone got a solution?
Thanks
Silverhammer
Welcome to the Forums @Silverhammer92.
Thanks for letting us know that you have tried disconnecting the two apps and then connecting them again to get it to work. Let me help you.
In regards to how the integration works, Fitbit will only sync activities over to MFP if they were tracked by your Fitbit itself. It will not sync manually logged activities for example. As for MFP syncing activities into Fitbit, they should be logged to Fitbit as manually logged activities. Has the situation continued since then? If some things are syncing, all of them should. Maybe it is only taking longer than the others.
Look forward to your reply.
