10-30-2019 14:29 - last edited on 10-31-2019 13:11 by LiliyaFitbit
Anyone having issues with MFP and FB syncing correctly? My breakfast from this morning is logged correctly in MFP but FB is counting it twice, both times with the wrong calorie count.
Best AnswerHi @SunsetRunner, it's nice to see you again in our Community Forums.
I appreciate your participation in the Forums and sharing the issue you're experiencing with Fitbit and MyFitnessPal syncing correctly. Thank you for providing the additional details. Keep in mind that if you sync your Fitbit at 11:00 AM, MyFitnessPal will only have information about your Fitbit calorie burn data through 11:00 AM that day. If only a partial day's worth of data is available, MyFitnessPal will combine the actual data from your Fitbit with an estimate of your calorie burn for the remainder of the day based on the daily activity level you selected when creating your MyFitnessPal account. This allows MyFitnessPal to create a more accurate estimate for your daily calorie burn based on the best data they have available from your Fitbit device at that time.
If the issue persists, I recommend doing the following:
If you continue experiencing difficulties, please revoke access to the integration with MyFitnessPal:
After relinking, you can verify that your accounts are syncing by using one of the following data points:
Let me know how it goes, I'll be around.
Best AnswerI understand how the estimated calories work, that isn't the problem. FB synced my breakfast twice, both times with inaccurate calories. I had to manually delete them from FB, and sync again. Then it finally went over to FB correctly.
If I can duplicate the problem, I'll take a screen shot.
Best AnswerHi @SunsetRunner, thank you for your reply.
I appreciate the additional details. Thank you for your efforts to take a screenshot. Our team will be glad to investigate further if the issue persists.
Thank you for bringing this to our attention as we're constantly working on improving our devices and user experiences.
If you have any questions, feel free to let me know.
