Hi guys,
I am thinking of buying a low-budget scale and found a couple of options:
- Renpho
- Xiaomi Scale 2
- Yunmai
So far I crossed out Renpho as a lot of people are complaining about quality etc.
Does any of you use Xiaomi Scale 2? Can you sync the data with Fitbit to get weight and body fat% in the app?
Thanks a lot!
Best AnswerI have the same setup, but it sadly doesn't sync body fat percentage from the Mi Fit app (Zepp Life) to Google Fit. It only syncs weight. The weight logs that get synced from Google Fit to Fitbit (using Health Sync) then can't be edited, so I can't manually add body fat to the synced weight log in Fitbit.
So if anyone is interested in syncing body fat to Fitbit, you might as well just go back to writing the data manually from one app to the other. If you only want to track your weight though, then this is a good solution.
Have anyone tried some third party open source apps for the Mi Body Composition Scale 2 such as openScale or Gadgetbridge?
Best AnswerHas anyone tried installing Health Connect (beta) from Google?? It does something similar to the app mentioned by Kinetik8 but it's free and supported and developed by Google
