06-18-2016 10:36 - edited 06-18-2016 13:17
Hello,
I've read a few entries in the forums about problems with syncing the Zip with Myfitnesspal account. However, none seem to have a solution to my problem.
The two accounts have always synced almost perfectly, but yesterday the data collected by my Zip regarding calories burned was not showing in myfitnesspal anymore. I waited for a while because I know that sometimes it's a bit slow to update but after a few hours and a new sync Fitbit-computer it still showed nothing. So I shut both websites and then opened them again, nothing. I unlinked the tracker on Myfitnesspal side and linked it again, nothing. I did it again, nothing. I unlinked it in both MFP and Fitbit sides and synced them again, nothing. I even cleared the history in my broswer, deleting cookies and stuff like that, but nothing. In the end I entered the exercises manually and let it go, thinking that maybe it was just a bug that needed fixing and that I'd check if it was the same the day after.
Well today is the day after and the accounts are not syncing, so my question is: what's left for me to try?
Thanks!
Best Answer06-18-2016 12:19
06-18-2016 12:19
Hi @AriPD
Have moved this thread from the Zip to the Third-Party Integrations section to increase the chance of getting a solution.
Your post will get more attention here.
Best Answer06-18-2016 13:17
06-18-2016 13:17
Thanks a milion Mystique, you're a star!
06-18-2016 15:14
06-18-2016 15:14
@AriPD I made a few posts in a similar thread that might help!
