02-06-2016 02:51
02-06-2016 02:51
02-07-2016 09:42
02-07-2016 09:42
Welcome to the forums @zumara! I'm also a MyFitnessPal user and I'll be glad to help on this. ![]()
I have seen this situation happen whenever both accounts don't have the same caloric budget to work with; so I recommend to disable Fitbit's Food Plan and add your MFP caloric budget as a main calorie goal.
I'll show you how to do it from my profile information. ![]()
First, you'll need to go to your Food log page and click on the arrows on Food Plan until you see the option "Edit Plan".
After you've done this, click on "Set a new Goal"
Add your starting weight and your desired weight and click next.
Instead of choosing the food plan options provided by Fitbit, click on "Set my own Calorie Target".
Now on MyFitnessPal, click on Goals and (unless you have an specific nutrition goal) click on "View Guided Setup"
Now on your Diet profile, add all the information required.
Now, you will get a Net calorie target for the day. Please bear in mind that mine is low because of my settings, but yours will be different.
Now, go back to your Fitbit Screen and add the Net Calorie target you were given for the day and click on Done.
Now you're set! The food you log in from MFP will automatically edit your Fitbit caloric values for the day and it will reflect on your MFP calorie budget for the day.
A couple things to consider about this:
Hope this helps! Let me know if you have any questions ![]()
02-08-2016 03:35
02-08-2016 03:35
Hi Helena
Thanks for your feedback.
Your solution is good for people which are not working with a fixed calorie deficit. I'm working with a 1000 calorie deficit per day. Can I input anywhere the deficit to get the correct eaten calorie values?
Many thanks for your help!
Tamara
Best Answer02-09-2016 07:02
02-09-2016 07:02
That's the thing @zumara, your caloric value for the day is Fixed on the Fitbit platform with the lowest number MFP is giving you (as a base) and it will continue adjusting on MyFitnessPal to grant more calories depending on your activity. Your In vs Out gauge (on Fitbit) will be disabled, because your caloric information will be displayed on MFP's screen.
MFP also has the option on its own to have a fixed caloric number for the day; however Fitbit adjusts this number depending on your steps.
Let me know if you have any questions, happy stepping! ![]()
Best Answer04-16-2016 09:04
04-16-2016 09:04
I have the same problem as of April 14, 2016.
Fitbit is adding extra food lines to my Dashboard calories screen. I enter food in "My Fitness Pal" and for some reason Fitbit is adding an additional line item which is not on my "fitness Pal' sscreen.
This just started to happen a few days ago. Before now there never ways a problem. I tryed rebooting both Apps etc but no luck. I can delete the extra entry on Fitbit Desktop but it does not up date my iPhone App.
04-18-2016 20:25
04-18-2016 20:25
Same issue here. I've noticed this over the past couple of weeks. Before that I never had a problem. Meals are being copied over 2, 3, 4 times from MyFitnessPal and showing up as different values for the same meal.
Here's an example from today. The 369-calorie dinner is the correct one; the 275-calorie entry is wrong and should be deleted:
This has happened every day this week and most days last week. I've been manually deleting the extra entries when I see them, but it keeps happening.
For what it's worth, I've tried unlinking and relinking my accounts -- twice -- and it didn't solve the problem.
04-19-2016 04:57
04-19-2016 04:57
Best Answer04-19-2016 08:57
04-19-2016 08:57
I read somewhere on this discussion to try this and it worked for me on my iPhone.
Log out of Fitbit App and delete App on the iPhone.
On iPhone, turn off Bluetooth.
Power OFF the iPhone and wait 2 minutes.
Turn power back ON to the iPhone.
Reload Fitbit App back on to the iPhone.
Turn Bluetooth back ON to the iPhone.
Check to see if multiple food lines have now been corrected and reading the same on
My Fitness Pal and Fitbit screens.
This worked for me and have not had the problem since.
Best Answer04-19-2016 10:23
04-19-2016 10:23
Best Answer04-19-2016 13:18
04-19-2016 13:18
Best Answer04-19-2016 19:01
04-19-2016 19:01
I'm using the web interface, not a mobile app. I don't have an iPhone.
I've tried unlinking and re-linking the apps, twice. No success.
Best Answer04-26-2016 05:11
04-26-2016 05:11
