09-19-2016
11:48
15:08
AndrewFitbit
09-19-2016
11:48
15:08
AndrewFitbit
MyFitnessPal has posted this update, indicating that they are aware of an issue affecting their integration with Fitbit's servers.
Affected users may see that they cannot link Fitbit accounts, or are not seeing data sync in either direction.
MFP indicates that that they are working toward a fix. We will update this thread when that happens.
09-21-2016 15:08
09-21-2016 15:08
09-19-2016 06:50
09-19-2016 06:50
Hi all, I'm hoping someone can help please?
My myfitnesspal app stopped syncing with my Fitbit, so I followed support instructions to revoke access on the Fitbit dashboard, and disconnect the fitbit app on myfitnesspal dashboard; then followed the Fitbit link to reconnect them, but everytime I select 'Allow' to let myfitnesspal connect with Fitbit, it comes up with the error 'Access token denied'.
Can anyone help please? How do I re-establish the access I revoked on the Fitbit dash?
Thanks
Jo
09-19-2016 07:29
09-19-2016 07:29
Having the exact same issue with my Surge.
09-19-2016 07:56
09-19-2016 07:56
I tried doing all of the above and am getting "Access token request failed." Help?
09-19-2016 08:04
09-19-2016 08:04
09-19-2016 08:14
09-19-2016 08:14
I'm also having the same issue but without the token error. It just takes me between allowing access on Fitbit.com to mfp's site, but it never connects.
09-19-2016 08:22
09-19-2016 08:22
Same problem here. MFP and fitbit didn't share info for the last couple of hours, so I unlinked them as advised in the older threads. Now I can't link them again with access token error.
Are the API's down/changed? Does not look like an individual problem.
09-19-2016 08:41
09-19-2016 08:41
Best Answer09-19-2016 08:49
09-19-2016 08:49
09-19-2016 08:54
09-19-2016 09:04
09-19-2016 09:04
Fitbit is not syncing to the MyFitnessPal app today.
The food I logged this morning isn't showing as calories in and my steps today are not showing on the MFP site...
I am not the only person with this issue either.
It seems to be for ALL Fitbits... I own a Flex... but people with other models noted the same problem
09-19-2016 09:22
09-19-2016 09:22
09-19-2016 09:29
09-19-2016 09:29
I revoked access in order to re-sync the 2 apps, and am now getting the "Access token request failed." error.
09-19-2016 09:32
09-19-2016 10:06
09-19-2016 10:06
Getting the "Access Token Request Failed" error also.
I'm getting a system is down somewhere. This only started this morning (I noticed the two systems synching fine last night).
09-19-2016 11:28
09-19-2016 11:28
The system is hosed. Not synching to MFP nor to WeightWatchers. Has to be an issue at FitBit.
09-19-2016 11:51
09-19-2016 11:51
09-19-2016 12:09
09-19-2016 12:09
Weight Watchers App just started seeing updates. Still nothing on MFP.
Best Answer09-19-2016 12:19
09-19-2016 12:19
I tried the http://www.fitbit.com/apps/myfitnesspal. address and all it did was take me to the "partners" page. not allowing me to ling the two at all. I cannot find anywhere on Fitbit to connect with My fitness pal. It just says its a partner app....
Best Answer09-19-2016 13:00
09-19-2016 13:00
I accidently revoked access to myfitnesspal in my fitbit settings and now when I try to add the fitbit app again to myfitnesspal it comes up with 'Access token request failed' Help please.
