11-06-2019 06:40
11-06-2019 06:40
So I think I've figured out what's happening here, but I'm not sure how to fix it.
I weigh myself every morning on my Aria 2 scale.
Is there any way to fix this? I want the data to sync over for the progress pics, but I'm getting really frustrated by losing the BF & BMI data!
Best Answer11-07-2019 15:53
11-07-2019 15:53
@gina_a Welcome to the Community. Thanks for the detailed information shared.
I was checking the information that's going to sync between MyFitnessPal and Fitbit and data that's going to sync from Fitbit to MFP is steps, calories and scale measurements. MFP toFitbit will sync logged food and activities. I believe this is why when you're uploading your progress photo to MFP the BF and BMI are lost.
I would like you to try to not upload the progress photo and check if your BF and BMI don't get lost.
Keep me posted!
Best Answer11-07-2019 15:55
11-07-2019 15:55
Not uploading a picture results in the BMI and body fat staying in the fitbit app.
is that the only solution though? I like having progress pics in the MFP app for motivation.
Best Answer11-09-2019 14:40
11-09-2019 14:40
@gina_a Thanks for getting back. As mentioned before, I would like you to try to not upload the progress photo to MFP and check if the data gets synced properly. If it syncs properly then it's the picture that's deleting the BMI and BF.
Keep me posted.
