04-26-2021
08:48
12:54
AndreaFitbit
04-26-2021
08:48
12:54
AndreaFitbit
Can someone tell me why my Versa 2 will not pick up my Blink notifications? The app shows up in my list of notifications, I have the box checked, and have synced my watch--still will not receive the notifications. Have also restarted my Versa--still no notifications. Has anyone else had this problem? Is it a glitch? Am I missing a step? I get all my other notifications with no problem. This is frustrating because I'm missing my Blink motion sensor alerts because I'm not always right by my phone...
04-27-2021
07:18
07:49
BraulioFitbit
04-27-2021
07:18
07:49
BraulioFitbit
Hi, there was an update in early April that affected this notification. I had the Charge 4 in March 2021 and received all notifications but as soon as I received the update in early April, the motion notifications from my Blink app stopped. I returned the Charge 4 and bought the Sense and still not working. It's weird that I still receive camera temperature and disarm and arm notifications to my Sense but no motion notifications. I am in the middle of talking with Fitbit Support and I tried everything to fix it but nothing has worked. I 100% believe that the update in early April messed this up. Hoping that support figures this out asap.
Moderator Edit: Formatting
04-27-2021 12:59
04-27-2021 12:59
Was hoping the Fitbit would show the snapshot from my Blinks XT mirrorless camera or Google nest doorbell. You do receive the notification but not the snapshot as my fossil or Samsung galaxy watch as they both do. Oh well back it goes. Was hoping to like this now that Google scooped it up but still way behind my other watches.
05-05-2021
04:17
10:06
AndreaFitbit
05-05-2021
04:17
10:06
AndreaFitbit
I am in the same boat That is why I got the Versa2 so I can monitor my home security camera and now its gone. I still have the boxed checked and re started my phone thought would work but nothing. I am very frustrated Fitbit please fix this problem I would hate to go to another watch just for this reason...
Moderator edit: format.
05-16-2021 07:57
05-16-2021 07:57
Same here. Contacted blink. No problems on their end. Will now contact Fitbit support.
05-17-2021
04:40
07:50
BraulioFitbit
05-17-2021
04:40
07:50
BraulioFitbit
Fitbit......Please do another update and change back whatever you did and
fix it where we can get our Blink notifications back....Everyone that has
Blink is frustrated...
05-23-2021
11:30
07:50
BraulioFitbit
05-23-2021
11:30
07:50
BraulioFitbit
Same here, very frustrating since it was working then all of a sudden quit, apparently because of the update...over a month and still no update to fix the update?
06-22-2021 18:25
06-22-2021 18:25
Has there been a resolution to this problem? I just got a Versa 3 and none of the Blink notifications are showing.
Thank you!
06-23-2021 04:52
06-23-2021 04:52
06-24-2021 08:49
06-24-2021 08:49
06-24-2021 19:44
06-24-2021 19:44
That's too bad. Hopefully they monitor these forums and see this thread.
07-13-2021 08:07
07-13-2021 08:07
definitely frustrating!
08-08-2021 19:22 - edited 08-08-2021 19:24
Has anyone found a fix for this issue or heard if it is being addressed?
I upgraded from versa 2 to sense at end of July and upon syncing first time got the 5.38 update and Blink is not notifying the Sense (no motion alerts, all other alerts work) even though everything has been set and reset multiple times.
Alerts arrive in phone no problem but not to sense. Most other app's notifications are going to sense.
Anyone hear of an update? TIA
03-18-2022 17:03
03-18-2022 17:03
Including this here because this page was the top search engine hit, regarding Blink not pushing notifications to Fitbit smartwatches.
This workaround using the Alexa app routines immediately fixed the issue for me, with no reinstalls or configuration resets:
1. Make sure your Blink app/account/camera is connected to your Alexa app/Amazon account already.
2. Open the Alexa app, press 'More' tab at bottom right, press 'Routines'
3. Press the (+) icon at the top right, enter a routine name like 'Motion notifications'
4. Press the 'When this happens (+)' section > press 'Smart Home' > press 'Camera' > press 'Detected' > press 'Next' at top right
5. Press the 'Add action (+)' section > scroll to and press 'Messaging' > press 'Notification' > enter 'Motion detected (CameraNameHere)'
6. Press 'Next' at top right to confirm, then press 'Save' at top right to enable the routine.
7. Wave your hand in front of your Blink camera, and your Fitbit smartwatch now receives the custom Alexa notification message!
03-19-2022 13:30
03-19-2022 13:30
This function is handled by your phone/ notification center and the answer will be specific to android or iOS and the fitbit app.
03-20-2022 11:05
03-20-2022 11:05
Great workaround to Blink notification not showing on watch thanks
