Best AnswerHi, @vickifit , sorry, not something I'm familiar with. I do not see it in the list of compatible apps. Touch your icon in the top left corner of the Fitbit app home page, swipe up to Compatible Apps.
Cheers
Gr4ndp4 | UK
Best AnswerHi, @vickifit, so far as synchronising your charge 4 is concerned you should look at How do Fitbit devices sync their data? and Why won't my Fitbit device sync? but these articles do not address your question about "Achievement"
Cheers
Gr4ndp4 | UK
Best Answer@vickifit so how did it get solved? Is one of the posts above an answer that worked. Or should you add your own explanation.
Marking the best answer will help others.
