@Dewar no it cannot. Here is a list of compatible apps currently with Fitbit: https://www.fitbit.com/partnership
If this is a feature you would like you can go to the Feature Request Forum and search to see if anyone else has suggested it, if so vote for it, if not post your request.
Best AnswerFitBit doesn't pair with FitBark BUT, FitBark pairs with FitBit. Open the FitBark app, tap on the menu icon, and you should see "Human Activity Tracker" option. Just follow the on screen instructions and you're all set. You can even compare your stats side by side to your pups.
I agree that this should be an option through FitBit, but until then, this will have to do. Hope it helps.
Hey! When added your fitbit to your fitbark, has anyone had the error message ? Thats what mine did and I don't even see the little icon to compare my fitbit with the fitbark - the side my side activity. help!
Hello there Fitbark users and welcome aboard to the Fitbit Community @Messyjessy3. Good to see you too @bella21.
@Messyjessy3 In this case Fitbark doesn't figure among our officially supported apps, this doesn't mean it won't work with Fitbit. Is just that the information we have available from Fitbark is very limited. If the app is giving you an error and the issue persist so far, I would recommend to contact Fitbark support. I'm sure they will be happy to help to address this error.
See you around and let me know if you have other questions.
