08-07-2024
11:37
11:54
LizzyFitbit
08-07-2024
11:37
11:54
LizzyFitbit
My peloton activities are no longer showing in my Fitbit app? All worked on Monday 5th Aug, but not 6th or 7th Aug?
Fitbit says its a Peloton issue and won't help. Suggest we may all need to go to another provider. Very dissapointing.
08-23-2024 08:29
08-23-2024 08:29
I got the same email. My workout sync without disconnecting/ reconnecting on the bike. Actually, my outdoor walking synced yesterday without any issue. Yay!
08-23-2024 08:39
08-26-2024 09:44
08-26-2024 09:44
Hi everyone, and welcome to our new members.
Thanks to all of you for your continued reports, and the steps that you've tried prior to posting. While I'm glad some of you sorted this out, I understand this isn't the case for everyone and I'd like to suggest the following steps to see if they work:
Please make sure that both, Peloton app and the Fitbit app, are updated to the latest version.
09-02-2024 03:58
09-02-2024 03:58
This doesn't work. It didn't worm 2 weeks ago, and it doesn't work now.
09-03-2024 16:59
09-03-2024 16:59
I followed these steps exactly and my exercise says still will not work.
09-03-2024 17:17
09-03-2024 17:17
I'm not sure if you have health connect still connected. I disconnected peloton on my fitbit app. Disconnected and removed health connect. Restarted my phone. Then I disconnected fitbit on my peloton bike and reconnected before my workout. See if any of this helps you. It fixed the problem. Initially when it fixed the problem, it was only for the day. Once fixed it showed my stats. Now it only shows that I did a workout and the time I worked out. It doesn't show other stats but it's at least connecting.
09-05-2024 09:50
09-05-2024 09:50
Hi @AlexVa and @Shikhab. @roseyred87 Welcome on board.
@Shikhab Thanks for sharing the steps that worked for you. I'm sure your post will help many other members!
@AlexVa and @roseyred87 Thanks for taking the time to try the steps suggested above. I'm sorry for this inconvenience and just to make sure, may I know if you've tried the advice shared above? If not, please give it a try to see if that works for you.
09-05-2024 10:19
09-05-2024 10:19
09-05-2024 10:28
09-05-2024 10:28
Yes. I tried your suggestion, but it didn't work. Everything was working fine for years. Then, Fitbit suddenly stopped importing the Peloton data. I changed nothing, so clearly, something broke on your end. Lots of people have this problem, but we aren't getting answers or solutions.
09-07-2024 14:08
09-07-2024 14:08
I did the exact steps you posted,
Remove access of Peloton on the Fitbit app
Force quit the Fitbit app and reboot your phone
Open the Fitbit app and try reintegrating with Peloton
Then, try syncing all your details to see if it starts to work
After doing that it didn't work. Two days ago or randomly started working but only for about 24 hours. It's back to not syncing even though nothing was changed.
09-07-2024 14:20
09-07-2024 14:20
09-10-2024 06:38
09-10-2024 06:38
Hi there,
How did you disconnect and reconnect? I revoked access and now there is no way for me to reconnect it seems.
09-10-2024 06:49
09-10-2024 06:49
09-10-2024 09:24
09-10-2024 09:24
09-10-2024 14:08
09-10-2024 14:08
Same! I finally got it to work again. I've tried all the steps again and I can't get it to work again.
09-10-2024 14:15
09-10-2024 14:15
I don't know why it worked yesterday but not today.
09-12-2024 09:16 - edited 09-12-2024 09:17
Normally I wouldn't question the advice given by what are generally the experts in the product (i.e. the manufacturers) and in this case therefore Fitbit/Google. However, given the frankly disastrous support that Fitbit/Google are giving in general and the mess of their app/infrastructure, then I have to surmise the solution of "disconnect and reconnect Peloton" is just wrong. He's my thinking.....
On my iOS device, the Fitbit app shows all of my Peloton activities, without any problem at all. I suggest therefore that the integration between Peloton and backend Fitbit servers is working properly. Now, unless Fitbit/Google have a completely wonky backend design (which to be fair, I wouldn't put past them), given that the Android app doesn't show the Peloton exercises, I assume this is a problem with the Android Fitbit app and Fitbit backend.
Attached are two screenshots, showing the same day (today). iOS Fitibit app screenshot shows a Peloton exercise. Android Fitbit app doesn't. Go figure?
09-18-2024 08:49
09-18-2024 08:49
I am using Health Connect and it shows it has synced with both Pelaton and Fitbit, but still my activities are syncing with Fitbit. It's super annoying.
09-18-2024 15:38
09-18-2024 15:38
Found a setting that may help. In the Fitbit App, from the today page, click user icon, Fitbit settings.
Scroll to Services, Health Connect on Today
Click radial button for Show data from Health Connect (default is Fitbit only)
Good news I have my Peloton workout bad news I was wearing my Fitbit Charge also so I have two workouts for the same activity. But that is an easy fix for next time.
09-18-2024 15:54
09-18-2024 15:54
