01-13-2016 16:48
01-13-2016 16:48
01-14-2016 06:44
01-14-2016 06:44
@Nldenissoff Welcome to the Fitbit Community! It's great to have you here! It's weird that your Fitbit account does not reflect the correct information from MFP integration and viceversa. In order to correct this, I recommend revoking access of your MFP account from your Fitbit Dashboard. After this, re-link both accounts again as it was the first time and log a workout or food for testing and verify if the issue gets corrected.
Keep me posted on the outcome and I'll be around my friend! ![]()
Best Answer01-14-2016 07:49
01-14-2016 07:49
Best Answer01-14-2016 07:55
01-14-2016 07:55
@Nldenissoff I believe that the problem is on MFP's end my friend. I suggest you to contact their customer support so they can investigate further their platform.
Let me know what they tell you and we'll see from there! ![]()
Best Answer01-14-2016 12:31
01-14-2016 12:31
I am having the same issues and have relinked my accounts, also. Guess I will contact MFP.
Best Answer01-16-2016 03:23
01-16-2016 03:23
@jessborch Thanks for joining us to our Community! Since you are experiencing the same problem and you already tried to re-link the accounts, I suggest you to contact MFP's customer service as well my friend since the issue might be on their end.
Hope to hear from you soon my friend! ![]()
Best Answer01-18-2016 10:29
01-18-2016 10:29
I am trying to contact them - they are not as good as you guys at replying.
Best Answer01-18-2016 11:00
01-18-2016 11:00
@jessborch I appreciate your good feedback regarding our responses my friend! However, as I can notice, the issue is on MFP's end and they can fix the problem for you.
Let me know what they tell you! ![]()
Best Answer07-13-2016 19:57
07-13-2016 19:57
In relinking FitnessPal and Fitbit, the instruction link you provided says to choose "Allow" and I can't find Allow anywhere. My FItnesspal app on my iPhone shows 0 Fitbit steps on my Homepage under the dashboard. Thanks.
Best Answer07-14-2016 05:18
07-14-2016 05:18
@Burf41 A warm welcome to our Fitbit Community! If you don't get the "Allow" button available, probably your MFP's account still has your Fitbit account linked. Disconnect your Fitbit account from your MFP's account and when on the re-linking process, go to the "Apps" section on MFP and click where it says "Get" under the Fitbit icon, once you click on it, you should get the page that has the "Allow" button.
Let me know how it goes my friend! ![]()
Best Answer07-14-2016 14:52
07-14-2016 14:52
Best Answer07-18-2016 05:28
07-18-2016 05:28
@SunsetRunner It's great to see you in the Community! So sorry to hear that your Fitbit account is not linking with MFP. Try clearing cash and cookies of your browser and try to re-link both accounts one more time. If the problem persists, take a screenshot of the error and attach it in this thread so that I can determine the cause of the issue.
Catch ya later my friend! ![]()
Best Answer07-18-2016 05:48
07-18-2016 05:48
Best Answer07-20-2016 05:54
07-20-2016 05:54
Hey @Jojoflojo it's great to have you in the Community! I'd like you to try re-joining to MFP by doing it through a computer. I'd like you to try this way since this will help us to determine if the issue is only through the Fitbit app or the online Dashboard as well. Don't forget to clear cache and cookies of your Internet browser.
Hope this helps my friend! ![]()
