05-27-2023
00:29
11:12
05-27-2023
00:29
11:12
I use Sense 2 in combination wit Sleepcycle. The data of my registered heart rate and body temperature in the Sense 2 are not transferred to the Sleepcycle app. How can I arrange that?
Moderator edit: clarified subject.
Best Answer05-27-2023 06:03
05-27-2023 06:03
Hello @SunsetRunner and welcome to the Community. Any data integration between another app and Fitbit is set by that app, not Fitbit. I searched and found this Sleep Cycle app and it says it doesn't support Fitbit integration. This is the only app that was in the search results. If you are using a different app, look for a Support or FAQ page to see that data types that transfer.
I'm moving your post to the Third Party Integration forum, a better fit for your question. Integration is between the Fitbit app and the other app. Generally, it isn't device specific.
Laurie | Maryland
05-27-2023 07:19
05-27-2023 07:19
If you're on Android you should be able to achieve that using Google Fit and Health Connect as a bridge as following:
Fitbit -> Health Connect -> Google Fit -> SleeepCycle
Best Answer05-27-2023 07:37
05-27-2023 07:37
Hi Dovopo, thanks but I have an iOS device.
