07-19-2021
02:48
18:54
LizzyFitbit
07-19-2021
02:48
18:54
LizzyFitbit
My Fitbit sense has stopped transferring calorie data relating to exercise to my fitness pal. I have re- installed both apps.
Moderator Edit: Clarified subject and updated label
Best Answer07-20-2021 19:06
07-20-2021 19:06
Welcome, @Arethusa29. It's good to see a new face around.
I've moved your post to the Third-Party Integrations board as there are more chances to get related replies here. Thanks for every step tried prior to posting. Before anything else, let me explain that your cardio exercises will sync from MyFitnessPal to Fitbit, but not the other way around. On the other hand, the calories burned recorded by your Sense should sync to MyFitnessPal correctly. Because this isn't your case, if your Sense is syncing correctly, please try the following steps to integrate Fitbit with MyFitnessPal one more time:
Hope this helps.
Best Answer09-01-2021 10:01
09-01-2021 10:01
My charge 3 is the same. I have done all the various thing suggested but it reverts back to the same problem, the following day
09-05-2021
15:12
08:26
09-05-2021
15:12
08:26
Hi @Jmcf. It's good to see you here in the forums.
Thanks for joining this thread and trying the steps shared above. I'm sorry this is happening to you and just to confirm, is your Charge 3 tracking and syncing your calories correctly? If that's correct, I'd recommend trying to contact MyFitnessPal to see if there is anything that can be do on their end to get your details transferred. You can find their contact details here.
