05-13-2017 12:54
05-13-2017 12:54
Please allow integration with Sleep as Android by Urbandroid. It would make the info fitbit gathers so much more useful.
05-14-2017 05:07
05-14-2017 05:07
That be wonderful
Feel free to add your suggestions to the 'Feature Requests' Sub Forum, where users can vote, add comments,.. if there's a certain interest then there's a chance the developers pick it up and it'll be developed.
Important to prevent duplicates Search if the idea already has been suggested and add your vote / comment!
Feature Suggestions
Click / Tap here to add new suggestion
Optionally when desired feel free to contact the Sleep as Android team to suggest integrating their app with Fitbit, as it's up to them to decide if wanting to team up with fitbit.
05-28-2017 07:18
05-28-2017 07:18
I also support integration with Sleep as Android by Urbandroid.
Sleep as Android by Urbandroid is the main app I use for tracking my sleep.
10-17-2017 06:09 - edited 10-17-2017 06:16
Their documentation specifies that Fitbit doesn't offer the API's they need. They may need a pointer in the right direction, or work is needed from both ends.
here's the discussion on the API support needed and Sleep as Android needs access to some of the RAW heartrate and motion sensor data (or at least have realtime/batched access through the android device that is syncing with the fitbit.
I'd love support for Sleep As Android, as it comes with a lot more options to help wake at the opportune moment. None of these features (except from the sleep graph) are currently supported by FitBit itself, so it'd be a great way to extend the fitbit's features. Maybe the Ionic will be different now that apps can run on the device itself.
10-24-2017 00:54
10-24-2017 00:54
I am with Garmin. Ready to switch to you if you make this happen.
