Hello @tortugita718, good to see you around. It might be a little tricky to re-associate the two accounts after their access were revoked. You can then re-link the two accounts by going to http://www.fitbit.com/apps/myfitnesspal. On this screen you should be taken to the third party apps that you can associate. Look for MFP app and then select "Learn more". Log on your account and then select "Apps" on MFP tool bar.
Once you have selected this option you should see the following screen:
Select the Fitbit App and press the option "Get" this will associate both of your accounts again.
Although I'm pretty sure you figured out and keep me posted how it goes.
