Strava issues
My blaze won't link with strava. I have disconnected and reconnected the apps several times, to no avail.
This is very annoying. Please help
21 REPLIES 21
I'm having trouble connecting today so if anybody has an idea let me know! Could it be needing updates on your phone?
Had the same issue, my recent runs didn't sync from fitbit to Strava.
Tried the revoke and reconnect method and got the 500 server error (but they say they're connected now anyway, despite the error) and those last two runs are still not showing in Strava.
Any ides?
Same issue here. I had to manually download the file from FitBit and upload to Strava. Hopefully FitBit will fix the integration soon.
{"statusCode":500,"error":"Internal Server Error","message":"An internal server error occurred"}
Revoked access from both Strava and FitBit and after trying to connect and getting the error above, the FitBit integration does show up in Strava, but not the other way around.
I'm having the same problem today, Surge to Strava is not working on either my phone (iPhone SE) or my online profile 😞 Worked fine yesterday
Getting exactly the same error code here.
Logged in ok to Strava and logged in ok to FitBit.
Was syncing fine, but only realised today it had stopped.
It had been a little sluggish/delayed for the past couple days.  But that seems to happen regularly.  My ride last night synced.  My ride this morning still has not (and sadly, probably won't...the last time this happened, even after they fixed it, previous rides prior to the error didn't sync).
I posted it here, along with the error, as it seemed to help the last time this occurred.
Well @celiawheelia, you are correct when you say your Blaze will not link to Stava.  You Blaze like all Fi5bit products l8nk to your Fi5bit account.
For information on how to link up your Fitbit account with your Strava account, see this post.  You might also wamt to read the i formation found   here, there are several links that are invaluable .
I did an update on my iPhone on both apps this morning after my walk, I'll head out again tomorrow and see is that has fixed it
Sent from my iPhone
Trying to (re(connect my Fitbit to Strava
The link https://strava.fitbit.com/ is currently giving an internal error:
I'm having the same issues as everyone else on here. I have tried to reinstate the fitbit>strava link and I get the same error message. Grrrrrrrr
This Is very annoying. I have reported it to fitbit directly. They are "looking into it"
This is very annoying. I have reported it to fitbit directly and they are "looking into it "
Have done numerous things and it's been very annoying. Have followed all fitbits advice and after much communication  they have agreed to look into it. So let's see. I have had the strava map for ages and it has worked fine until today
All the fitbit link to Strava does is send you to your strava account.  Why not justblog in at https://www.strava.com/login, then click on the connect buttun to connect to fitbit.
It sends my full run data to my strava account, maps,mile times etc. I was happy with how it worked, managing the two singly via my fitbit.
I didn't realize this thread was revived.
I posted about it this morning in a new thread.
https://community.fitbit.com/t5/Third-Party-Integrations/Strava-not-syncing-again/m-p/2108744#M18388
unfortunately error has raised its ugly head again
Just trudging along
Does that mean it's broken both ways then?  For some of us anyway?
Hi Everyone,
I've merged two threads together. There was an issue yesterday with workouts syncing from Strava to Fitbit that has since been resolved. Thank you for your patience and for taking the time to report this.
Your workouts that failed to sync over from Starva to Fitbit yesterday should be queued up and sync over when syncing today. However, there might be a chance some workouts might not sync over. If it's a GPS activity you can manually upload it to Strava.
Actively managing your weight? Find accountability buddies on the Manage Weight board
