03-13-2018
14:29
12:05
SelmaFitbit
03-13-2018
14:29
12:05
SelmaFitbit
I've just bought a Fitbit Alta HR, and I already use a Garmin for cycling and another third-party sports watch for running. I record activities from my Garmin and running watch on Strava, and have just linked my Fitbit and Strava accounts. So far, I can't see that anything has transferred from Strava to Fitbit (ie today's run), so please could you confirm if I should be able to see activities uploaded to Strava from my Garmin or running watch via the FitBit app?
Thanks.
Moderator edit: label
Hello @lawsofmag, awesome to have you around in the Fitbit Community, welcome aboard! I was reading you have questions regarding the integration between Garmin, Strava and your Fitbit account.
In this case your exercises may sync from Garmin to Strava and this data recorded in Strava may sync to Fitbit as manually logged activities, but will not include GPS or heart rate data if is available. I'm saying this as a probability, since the exercises were not originally recorded in Strava and Fitbit is not compatible with Garmin.
Have you seen the same behavior with exercises recorded directly in Strava. The behavior should be the same as I mentioned before, but if you are not able to see manual either manual activities in your exercise history coming from Strava, I would like to recommend to try these steps:
Hope this helps and let me know if you have other questions.
