06-06-2019 08:01
06-06-2019 08:01
I use to swim flex2 and moov now. The flex2 I see is more accurate in terms of the amount swam but moov gives more data. My moov now does not record the meters swam well. On the contrary that many people my moov records other meters. Yesterday it registered 2000 meters and I do not think I have swum more than 1300. Does someone have the same thing? Found a solution?
08:17
09:02
06-07-2019
08:17
09:02
Welcome to the Forums @Horacio1975ar.
Thanks for sharing your experience on the situation.
My question in this case would be, are you using both separately, or if you have your apps connected to each other? Please keep in mind that this board is meant to discuss apps that connect or are connected to your Fitbit account.
I look forward to your reply.
