06-06-2019
11:23
17:41
SilviaFitbit
06-06-2019
11:23
17:41
SilviaFitbit
My versa will not sync my steps on to myfitness pal. I need help
Moderator Edit: Clarified subject and labels
Best Answer06-06-2019 23:44
06-06-2019 23:44
There has been an ongoing issue with the link to MyFitnessPal. Keep an eye on the following thread for the latest updates from fitbit:
06-07-2019 12:29 - edited 10-19-2023 16:21
Welcome to the Community Forums @grammy54! As my friend @SteveH has mentioned, we are aware of a syncing issue between Fitbit and MyFitnessPal (MFP) that has been going on since June 3rd.
Since @SteveH has provided you with the information you were looking for, I made his post as the solution for your previous post. Highlighting the solution may be discovered more easily by other community member's facing the same questions or issues as you. You can read more about Accepted Solutions here.
I've moved your post to the Third-Party Integrations as there are more chances to get related replies here.
