Hi All,
Will Fitbit sync data in Garmin Connect via Strava? For example, if I go for a run with my Garmin Forerunner and upload the run into Garmin Connect, then sync Garmin Connect with Strava, will the data sync with Fitbit through their integration with Strava?
Thanks
Vinny
Best AnswerI don't think it will. Tried it in a similar situation trying to get runkeeper info onto the fitbit dashboard.
Strava seems to have the most complete two way sync with fitbit, but I seem to find entries going onto the strava dash don't make it over to Fitbit.
Syncmytracks on the Google play store works for me, it could work for a garmin import sync too?
05:31
09:21
06-12-2016
05:31
09:21
Hi there guys @vjlynch @SunsetRunner, good to see you both in the Community! 🙂
I personally don't use Garmin or Strava but what @SunsetRunner says sounds pretty accurate. I would think that if an app syncs without a problem to Fitbit and you sync another app to that app, it would transfer over to Fitbit as well but I would say that just to be sure try it out yourself and see if it works for you and be sure to let us know so other users with the same question can find an answer to this.
See you around!
