12-02-2016 07:13
12-02-2016 07:13
[Charge HR; Android]
FitBit has not synced with AARP's "Rewards for Good" program for more than a month. Even when it was syncing, doing so was sporadic, e.g., about one out of every four or five days.
The website/app/device does sync with Walgreens, by the way.
Anyone else seen a similar problem? Is there a fix out there?
12-02-2016 11:28
12-02-2016 11:28
2labz wrote:
- Yes: I did contact "support." That did not work (in my experience, support usually can't help unless they already have a script for the problem, and they apparently don't have one for this).
Which support team did you contact? Because you would need to contact AARP about this.
From looking at their community, looks like they were aware of recent syncing issues:
https://community.aarp.org/t5/Introduce-Yourself/Fitbit/td-p/1620083
12-02-2016 11:36 - edited 12-02-2016 11:44
Apparently support does have a script: blame it on the other end. But FitBit staff wrote and supplies the API, and if the API doesn't work it isn't the remote client's fault.
12-02-2016 13:17
12-02-2016 13:17
@2labz Fitbit did not build AARP's integration. They are the ones that built it, and they are responsible for maintaining their integration. That's why you would need to contact them.
If there was an issue with our API, it would be more than just AARP with issues.
12-03-2016 07:46
12-03-2016 07:46
Same problem here with a Flex. Emailed AARP with the problem; got a reference number and call back number 1-888-842-2891. They credited my rewards account for the missing points over the phone. Also referred me to fitbit support and suggested a call back to AARP tech support during business hours on a weekday for a fix. Though after viewing Andrew's replies, maybe AARP is the culprit?
In my case all of November was missing. There was a similar problem earlier this year that was fixed for a while. During this time, I found my flex would synch better if it was fully charged and all other bluetooth devices were completely off and out of the room.
12-03-2016 08:05
12-03-2016 08:05
I give up.
All this is a case study in what's wrong with new technology: in order to give the kiddies in Silly Valley free lunches and Friday happy hours, customer support (including this ridiculous "community" model) is outsourced to 3rd-party vendors who don't give a rat's hiney about the products OR the clients. After all, who wants to give all those cool bennies to some $13.95/hour drone when you can waste buckets of cash making your code monkeys happy while just about guaranteeing that they get almost no real work done. Stupid, stupid, stupid.
12-03-2016 13:13
12-03-2016 13:13
12-04-2016 03:46
12-04-2016 03:46
