11-25-2018 23:17
11-26-2018 02:39
11-26-2018 02:39
Looks that way, my last run hasn't sync'ed either, 2 hours after I finished. Usually happens within about 15mins.
11-28-2018 13:53 - edited 11-28-2018 13:58
yep mine's stopped syncing since yesterday (28th November) too
i've posted in another thread from when it happened last time:
Best Answer11-28-2018 14:07
11-28-2018 14:07
spoke to soon - has just started working again, my two outstanding rides (one from this morning, one from yesterday arvo) have just come through!
Best Answer12-03-2018 11:02
12-03-2018 11:02
Hello @flash_222, @n00dle and @SunsetRunner.
@SunsetRunner and @n00dle, in this case I'd recommend that you try removing the connection between the Fitbit app and Strava. Then reconnect them again and they should start syncing from that point on.
Let me know if you have any further questions.
18:43
07:55
LanuzaFitbit
12-05-2018
18:43
07:55
LanuzaFitbit
i'm now having to remove and reconnect the strava-fitbit connection every time i want to upload an activity.
i wait 12-24hrs before doing so, just to make sure it's not coming through automatically, and once i reconnect the outstanding activities come through immediately.
cheers
patrick
12-05-2018 22:24
12-05-2018 22:24
Hi @flash_222! I am curious if this happens when you try to sync a Strava activity to Fitbit or the other way around (fitbit to strava)?
Thanks!
Best Answer12-07-2018 08:00 - edited 12-07-2018 11:34
Hello @flash_222 and @raduenoiu.
@flash_222 Thanks for that update and sharing the steps that you follow to get the information to sync between the apps.
@raduenoiu when the apps are connected they should work both ways for certain activities or information.
Let me know if there are any further questions.
