11-21-2016 14:19 - edited 11-21-2016 14:20
My Charge 2 is still inaccurately recording walking distance and steps. My MapMyRun application is counting correctly. I know I can sync my Charge 2 with MMR, but which will be the overriding data? If the Fitbit data will override the MMR data, then I definitely don't want to do this, becuase MMR is the only accurate account of distance that I currently have.
Today Fitbit recorded a 2.16 mile walk, and MMR calculated a 3.11 mile walk. I was using GPS and on a route that I regularly use, so I know the 3.11 is accurate.
Best Answer12-02-2016 07:53
12-02-2016 07:53
I want to give you a bump because I am having MMR sync problems with my Charge 2 as well.
Best Answer12-02-2016 10:56
12-02-2016 10:56
@SophieTrack If you're using both to track the same run, it will double count, not override. Not sure you want that either.
@lacandona Syncing issues as in linking the accounts? Or did you mean you're seeing the same thing as @SophieTrack?
