08-07-2020
16:23
07:26
08-07-2020
16:23
07:26
Hi everyone,
There's currently a syncing issue between Fitbit and Strava. We’re currently working to resolve it and hope to have a fix soon. Be sure to keep your Fitbit device and app up-to-date to ensure you receive the quickest resolution.
We're sorry for any trouble. We appreciate your patience and look forward to getting you back on track.
Subscribe to the thread to receive any updates or fixes to this.
Please let us know if there's anything we can do to assist you in the meantime.
08-04-2020 03:59
08-04-2020 03:59
and also deleted both apps and re-installed.
Best Answer08-04-2020 04:01
08-04-2020 04:01
@LiliyaFitbit where is the new thread please? I am also having issues of my GPS Fitbit activities not downloading to Strava after trying varies trouble shooting options.
Thank you
08-04-2020 04:58
08-04-2020 04:58
I've been having this problem on and off, but consistently since 28 July. Nothing comes through to Strava, and I've tried all the suggested fixes. Very, very frustrating.
08-04-2020 05:00
08-04-2020 05:00
Hi- thanks, that's useful. Do you think that the data that's stuck in the black hole will come through? I have tried to expert the data from FitBit manually but it's a csv file that isn't compatible with Strava - any ideas?
Best Answer08-04-2020 05:26
08-04-2020 05:26
you should be able to export it as a .TCX file and then manually import it into strava. This is what ive been doing since it stopped working. As long as its got GPS data in the activity you have done, it will import into strava via the .TCX file upload option
08-04-2020 05:37
08-04-2020 05:37
I have had the Fitbit - Strava connection in place for a few years, mine stopped working 1-2 weeks ago too.
Having to download/upload TCX files manually at the moment.
Very frustrating.
08-04-2020 05:41
08-04-2020 05:41
Same issue for me too. Have had the fitbit - Strava link in place for a few years.
Stopped working 1-2 weeks ago, very frustrating.
Having to manually transfer TCX files currently.
08-04-2020 06:35
08-04-2020 06:35
I've been having the same issue as well. My last synced run was last Monday. Since then I've had to download the .tcx file and upload manually to Strava.
08-04-2020 07:22
08-04-2020 07:22
Best Answer08-04-2020 08:28 - edited 08-04-2020 08:30
When I go to the activity that I used GPS for at the top right hand corner there are 3 dots. When I click or tap on them it gives me the option to "Export TCX File". It then downloads to my device or computer. Then I upload it on the Strava website.
08-04-2020 15:15 - edited 08-04-2020 15:31
@SunsetRunner Hi there and thanks - I was trying from the desktop Fitbit app on my MacBook. I was able to do it from my phone and have successfully imported one run! Now for the rest since 28th July. Cheers.
15:20
07:22
08-04-2020
15:20
07:22
Hi everyone! Thank you for the information shared and the troubleshooting tried.
In order to provide you with the best information possible, please reply to the following questions:
- Are you still experiencing issues syncing Fitbit activities to Strava mobile app?
- Are you experiencing issues with Fitbit and Strava integration or the Strava app on your watch?
Looking forward to hearing back from you.
08-04-2020 15:28
08-04-2020 15:28
08-04-2020 15:30
08-04-2020 15:30
Hi Silvia - thanks for the message. I am still having problems but thanks to fellow users I think I am now sorted with manually exporting and importing the activities as files.
The mobile apps are not communicating with one another. I have noticed that the authorisation at the Strava end seems to disappear. The Strava App on the watch also hasn't recorded a run since 28th July, same as the Strava App on the phone and desktop. I subscribe to both FitBit Premium and Strava and I am not able to use them properly at the minute which is disappointing. Any insight into what is wrong? Thanks.
08-04-2020 15:37 - edited 08-04-2020 15:38
Same here. I've been logging activities with GPS with my Fitbit Versa, but it's been already a few weeks that nothing is being synced with Strava. I've tried disconnecting and reconnecting the apps from both sides, and also tried this link:
Nothing helped at all, ever.
I'm completely frustrated with Fitbit support also. I don't see any response from them. BTW, it took me ONE year to get them agree that my original Versa was faulty...
Fabián
08-04-2020 15:38
08-04-2020 15:38
Yes the issue is still there although it no longer seems to remove the device from Strava connected devices anymore, but still not automatically syncing any activities.
08-04-2020 21:30 - last edited on 08-05-2020 13:09 by LiliyaFitbit
Hi Silvia,
im still having to manually upload activities.
Moderator edit: format
Best Answer08-04-2020 21:53
08-04-2020 21:53
Thanks for the reply on this matter. Quick thought, could this be trusted to the fact that Strava just went online with their new subscription platform with fewer free features. Could the free sync feature now be gone??
Best Answer08-04-2020 22:07
08-04-2020 22:07
Best Answer08-04-2020 22:24 - last edited on 08-05-2020 13:08 by LiliyaFitbit
Hi, I took out a subscription with Strava a few months back so that’s not the case for me but am now more frustrated as I’m paying for something that at present isn’t fit for purpose 🤷:female_sign:
