03-05-2021
04:00
09:40
AnaFitbit
03-05-2021
04:00
09:40
AnaFitbit
Having some problems with synched runs on Strava
Previously I've been having problems with my Charge 4 losing GPS single towards the end of a run resulting in the distance being wrong and map also not being complete. Therefore I set up a strava account so that I could also track runs on my phone and would then have the full data if the charge 4 gps dropped out again. However I now end up with 2 sets of data for the same run on both apps. I am finding that when I delete the strava run (as strava always calculates the distance as less) from fitbit the Fitbit version of the run then loses the map on the Fitbit app even though on the fitbit app the map is always there for the Fitbit run and it not there for the strava run which is the one I delete.
Is there anyway around this and can I get the maps back on fitbit (they are still there on the synched run on strava)? Ironically fitbit now not losing gps so I could revert to not also recording the run in strava although I am sure once I do that the original problem with gps will re occur !
Apologies for long and convoluted first post!
