05-31-2019
07:03
10:31
LanuzaFitbit
05-31-2019
07:03
10:31
LanuzaFitbit
So data is syncing between myfitnesspal and fitbit, but once a today ends, if I go back and add some food to yesterday or an exercise to yesterday, it will never sync to fitbit. Todays data will sync instantly but yesterdays does not. Is there any way to get around this? I tried revoking the connections and reconnecting, but the problem still comes up. Most days its okay, cause I get it all in that day, but every once in a while I forget to put in dinner that night and put it in the next morning, but if I do, it never works. Thanks!
Welcome to the Forums @adqttr.
Thanks for sharing your feedback on the matter.
In this case it is the way the apps are designed to work. They only sync information for the current day and do not sync retroactively.
Maybe you could post about it in our Feature Suggestions board. That way other users can comment and vote on the idea to show their support. If you do post in there, be sure to read the FAQ to better understand how that board works.
In order to get the information that you forgot, the best option would be to manually log them on both ends to make sure that the data on both matches. It is definitely not a solution but it would be the only way to make sure both ends show the same thing.
Let me know if there are any other questions on the matter.
