07-26-2016 21:07
07-26-2016 21:07
07-20-2016 13:31
07-20-2016 13:31
Best Answer07-20-2016 16:27
07-20-2016 16:27
@Mom25Boys there is another thread with the same issue. it appears to be global and a fibit/myfitnesspal issue they are working on. super frustrating. 😞
07-22-2016 10:38
07-22-2016 10:38
The steps tracked or the adjusted calories. MFP will sync with the Fitbit app however....
I have tried the revoke access route, and have the MFP app set to use the fitbit as my step counter etc. I have deleted both apps and reinstalled. Nothing.
I am on a note 5 running 6.0.1 marshallow if that makes a difference..
Best Answer07-22-2016 12:05
07-22-2016 12:05
Hi @cpotts13
Have moved this thread from the Charge HR to the Third Party Integrations section to increase the chance of getting a solution.
Your post will get more attention here.
Best Answer07-22-2016 13:38
07-22-2016 13:39
07-22-2016 14:55
07-22-2016 14:55
Best Answer07-22-2016 15:35
07-22-2016 15:35
@bruinsgirl33 @cpotts13 If you have a screenshot + the full URL of the error page you're seeing then that would be helpful.
Best Answer07-22-2016 16:05
07-22-2016 16:05
Yes sure... However I am not recieving an "error page" per say. The apps are connected, the myfitnesspal will not show any data from the Fitbit app, as evedent from the zero step counter on the diary and lack of calorie adjustment. But the fitbit app shows data from the myfitnesspal app..
Best Answer03-20-2017 15:36
03-20-2017 15:36
Hello is there instructions on here to sync the Fitbit with Fitness pal using a Android phone? My iPhone works but haven't been able to get my wife's galaxy 6 to link. It says it's connected but it's not showing any of her data
thanks
Best Answer03-20-2017 22:32
03-20-2017 22:32
I just signed up for this app called; trovey: https://www.trovey.co/
It allows you to aggregate data from myfitnesspal and fitbit as well as any fitness, wellness or medical app you might use - so you can get all of your info in one location. Its pretty cool, check it out!
Best Answer03-21-2017 08:04
03-21-2017 08:04
Hi PEIForbes,
There's a cool new app that is in private beta right now that syncs up all your health & fitness accounts in one location. Here's the link to sign up to use their app:
They might be worth checking out!
-Jen
