01-24-2016 05:38
01-24-2016 05:38
01-24-2016 06:12
01-24-2016 06:12
Hi, @MikieS have you tried following the steps in this help article: https://help.fitbit.com/articles/en_US/Help_article/How-do-I-connect-my-Thermos-Connected-Hydration-... ?
Let us know if that gets you going.
01-24-2016 08:03
01-24-2016 08:03
03-14-2016 08:21
03-14-2016 08:21
After paying more than $45.00 dollars for a bottle of water now does not work as promised, not sync with fitbit since January 2016
03-14-2016 10:04
03-14-2016 10:04
@rickycastro Make sure you've tried all the steps in this help article to get your Thermos connected properly. If that still doesn't work, you can contact Thermos for assistance.
Best Answer04-01-2016 10:40
04-01-2016 10:40
I also just purchased the 60.00 Thermos Smart Lid bottle. The Thermos and the corresponding app work fine. The water intake will not sync over to my fitbit app. If I log out of my fitbit app then log back in then the water intake shows up. I have tried all of the options listed on both companies web sites, to no avail. I have spoken to fitbit who simply says "sign out and back in", which should not be required. I have called Themos and left a message for a call back....two days later still waiting.
Getting no where.
04-12-2016
11:24
08:56
HelenaFitbit
04-12-2016
11:24
08:56
HelenaFitbit
Best Answer04-12-2016 11:38
04-12-2016 11:38
any status for Thermos bottler doesn't sync into Fitbit
Best Answer04-12-2016 11:45
04-12-2016 11:45
@rickycastro As I previously mentioned, the steps in this help article should help to get your Thermos connected properly. If that still doesn't work, you should contact Thermos for assistance. They offer support for their products.
Best Answer04-19-2016 12:03
04-19-2016 12:03
For those of you still having issues. I went through all the step and all that other jazz. Here's what fixed it for me. I suggest you try it. Go to: https://www.fitbit.com/user/profile/apps# then revoke access for the Thermos Smart Lid. Go into your fitbit app on your phone, profile, firbit setup, profile, then tap Deathorize. Next go back on screen and make sure "Enable Fitbit" is turned off. Then close the app on your phone.
Go back into the app and re-enable Fitbit in the Thermos app. Log back in and give access to Thermos to access your Fitbit. Fill up the bottle full, sync it in the Thermos app. Quickly empty the bottle and sync the progress again in your Thermos app. Give it a minute and reload the fitbit app and you should see it syncing again.
Worked for me so hopefully it'll work for you too.
05-26-2016 13:03
05-26-2016 13:03
That didn't work for me. Still...isn't syncing.
Best Answer05-29-2016 11:53
05-29-2016 11:53
@dnwalch The steps in this help article should help to get your Thermos connected properly. If that still doesn't work, you should contact Thermos for assistance. They offer support for this product.
Best Answer06-10-2016 04:18
06-10-2016 04:18
Ok, I got mine to start syncing again.
1. Revoke Access in the dashboard via the web browser.
2. Delete Both Thermos App & FitBit App on my Phone (iOS)
3. Restart Phone.
4. Reinstall Both Apps.
5. Log into fit Bit app.
6. Open Thermos App and reset up your Bottle/Smart Lid.
7. Once the thermos app is properly connected to the fitbit app. Fill your bottle. Pour the contents out in segments as if you were sipping. Once empty, refill bottle.
8. The thermos app shoul show a full bottle with 24oz consumed. After a minute or so, this should have synced to the fit bit app. Mine did not!
I NEEDED TO QUIT THE FITBIT APP ON MY PHONE AND REOPEN IT TO SEE THE WATER CONSUMPTION.
I repeated the filling and empting of the bottle sevarl times and I need TO QUIT THE FITBIT APP ON MY PHONE AND REOPEN IT everytime to see the FitBit app update my water consumption!
I am wondering if i even needed to do all the app reinstalling or did I just need to quit the app after every finished bottle.
Anyway, This worked for me.
THIS IS A PROBLEM WITH THE FITBIT APP, NOT THE THERMOS APP.
Moderator please pass this on to FitBit app developers.
06-10-2016 08:28
06-10-2016 08:28
robert_FL....Thanks much! That worked. I really appreciate the post.
06-10-2016 08:35
06-10-2016 08:35
I am glad it helped someone!
Best Answer07-16-2019 17:21
07-16-2019 17:21
This is exactly my issue with a Charge 3
09-27-2020 11:02
09-27-2020 11:02
There is no article. No information anywhere for having issues with syncing with Fitbit.
Best Answer09-27-2020 11:05
09-27-2020 11:05
I realize this is 4 yrs later, but there is no article today to assist getting my Thermos connected to my Fitbit.
Best Answer09-27-2020 11:27
09-27-2020 11:27
I realize it's 4 yrs later, but I believe THIS is the only thing that worked!
Best Answer09-27-2020 13:03
09-27-2020 13:03
I’ve had no help on this issue and had 3 failed charge 3s. On to a charge 4 now and don’t use the thermos. Annoyed that I couldn’t sync it anymore. Didn’t try with charge 4.
