06-25-2020
07:59
13:03
SilviaFitbit
06-25-2020
07:59
13:03
SilviaFitbit
i’ve been using Fitbit for a decent amount of time now. And I am fairly new to Peloton. Recently I have been trying to track all of my calories as well as the calories that have been burned. I am noticing that when I set my Fitbit versa light to exercise mode on bike setting, the calories burned are far more than the calories that Peloton syncs for the same 20 minute ride. I am trying to figure out which calories are the calories I’m actually burning. I hope someone can help! Again I am very new to the healthy lifestyle so just trying to track and monitor everything. For example for a 20 min ride, peloton says I burned 153 calories where fit bit Bike exercise setting says 327 calories. I do not have a heart rate monitor connected to the peloton so is this what could be the issue? Someone HELP! 🙂
13:02
08:26
06-27-2020
13:02
08:26
@Demersjaclyn A warm welcome to the Community. Thanks for mentioning that you're using Fitbit and Peloton.
The calories burned that Peloton are showing might be an average of what you should burn. However, I'd recommend to contact them for more information on how they are tracked.
In regards to Fitbit device, it combine your basal rate (BMR)—the rate at which you burn calories at rest to maintain vital body functions (including breathing, blood circulation, and heartbeat)—and your activity data to estimate your calories burned. If your device tracks heart rate, your heart-rate data is also included, especially to estimate calories burned during exercise. The number you see on your Fitbit device is your total calories burned for the day.
I'll be around if you have any additional questions.
