10-28-2016 14:26
10-28-2016 14:26
10-04-2016 02:54
10-04-2016 02:54
I have tried everything and after this last update on my Blaze, my apps no longer communicate. I have uninstalled, reinstalled, gone onto my computer and unlinked and linked back. I just cannot get these to sync and it's really really frustrating! Any suggestions I haven't tried yet?
10-04-2016 04:26
10-04-2016 04:26
I've moved your post to the third party app forum.
My suggestion would be to revoke access to MFP from Fitbits settings. Then link again.
I've also moved your post @mpruitt an. Very much doubt it has anything to do with the tracker since it is the accounts that connect
10-04-2016 18:01
10-04-2016 18:01
10-04-2016 20:22
10-04-2016 20:22
10-05-2016 07:50
10-05-2016 07:50
Hi, @ChelsyReigh! Fitbit activity does not sync to MFP, only steps. Activity syncs the other way around (MFP to Fitbit). I believe everything between the two apps is a one-way street.
MakMak | Community Council
10-06-2016 06:00
10-06-2016 06:00
A warm welcome to the Forums @Crystal2301. If your Fitbit account is not syncing with your MFP account, I recommend doing the following from a computer:
1. Sign into your Fitbit dashboard.
2. Click the gear icon in the upper right corner and select "Settings" from the drop-down menu.
3. On the left side of your screen click "Applications."
4. Under MyFitnessPal, click "Revoke Access."
5. You can then re-link the two accounts by going to http://www.fitbit.com/apps/myfitnesspal.
After relinking, you can verify that your accounts are syncing by using one of the following data points:
1. On Fitbit you can check for your meal summary and logged activities from MFP.
2. On MyFitnessPal, go to "My Home," then "Check-In." You should see your weight, Fitbit Steps, and Fitbit Sleep Minutes.
I hope this helps, let me know the outcome.
10-06-2016 17:14
10-06-2016 17:14
10-08-2016 13:43
10-08-2016 13:43
@ChelsyReigh Welcome to the Community! As @MakMak mentioned, your activities won't sync to MyFitnessPal. The way data will be synced will be like this:
Fitbit to MFP : steps and weight. MFP to Fitbit : activity, food and weight. You can learn more about this integration here.
Hope this helps!
10-08-2016 13:56 - edited 10-08-2016 13:57
Welcome to the Community @mpruitt! The best thing to do here is to contact MyFitnessPal directly so they can further investigate it.
Thanks for moving the post @Rich_Laue!
Hope this helps!
10-11-2016 14:05
10-11-2016 14:05
10-12-2016 06:27
10-12-2016 06:27
It's great to see you around @Samirella. If your MFP account is not syncing with your Fitbit account, I recommend following the instructions provided in this post to fix this inconvenience. After those steps your accounts should sync without an inconvenience.
Let me know the outcome.
10-17-2016 05:15
10-17-2016 05:15
i have tried everything possible to get mine to sync and nothing! Please can someone help me???
10-17-2016 06:36 - edited 10-17-2016 06:36
@Apples2918 Things to try:
Hope this helps!!
10-18-2016 11:12
10-18-2016 11:12
10-19-2016 01:16
10-19-2016 01:16
10-19-2016 01:54
10-19-2016 01:54
10-19-2016 02:09
10-19-2016 02:09
same here 😞 I tried disconnecting as well as uninstalling both apps....
10-19-2016 04:16
10-19-2016 04:16
A warm welcome to the Forums @postpartumme. If your MFP account is not syncing with your Fitbit account, I recommend checking this post, where I am providing some steps to fix this inconvenience.
10-19-2016 06:17
10-19-2016 06:17
Hi. I am having the same issues. I tried revoking and adding again and still no steps or food is syncing?
Thanks!
Kathy
