03-26-2016 18:42
03-26-2016 18:42
Best Answer03-27-2016 04:27
03-27-2016 04:27
Hi @Marak
Moved this thread from the Charge to the Third-Party Integrations section to increase the chance of getting a solution.
03-27-2016 04:27
Hi @Marak
Best Answer06-30-2016 16:10
06-30-2016 16:10
@Marak A warm welcome to the Community! I'll be more than happy to help you connect these two apps and enjoy the best of each one.
So, activities tracked by Fitbit are converted to "PointPlus" in Weight Watchers. To start connecting both accounts do the following:
Once logged in, you will be redirected back to the Weight Watchers Settings page.
Hope this helps.
@SunsetRunner Thanks for moving the post.
Best Answer10-11-2017 10:09
10-11-2017 10:09
I have been trying to connect for the first time and I try this process and am not even given the option to log into Fitbit - it takes me straight to an "error 404" page. I tried revoking access on Fitbit and it still does it. Any further suggestions?
Best Answer10-16-2017 12:00
10-16-2017 12:00
I have tried this several times; it does not work. I have Fitbit Charge HR and using an Android phone. Have tried it on both my phone and on my computer.
Best Answer10-16-2017 12:01
10-16-2017 12:01
I am also getting that same message. Neither Fitbit tech support or Weight Watcher tech support has been able to help. Hope someone has the solution.
Best Answer10-16-2017 12:03
10-16-2017 12:03
How did you do this - move the thread and did it work
Best Answer11-06-2017 14:19
11-06-2017 14:19
Im getting this too... did u find a solution? So frustrating.
Best Answer11-06-2017 14:21
11-06-2017 14:21
Is there a solution for this yet? I have the same problem x
Best Answer11-10-2017 09:39
11-10-2017 09:39
Hey @Sarahliz123, @MamawG45 and @FitBek! I would like you to double check that you're following this procedure to connect both accounts.
If after confirming this, you're still having issues. Please contact Weight Watchers so they can continue helping you.
Hope this helps! Keep me posted.
Best Answer11-10-2017 09:54
11-10-2017 09:54
Best Answer11-11-2017 03:48
11-11-2017 03:48
Oops, the Dedie45 is my new Weight Watcher name.
Best Answer11-13-2017 14:46
11-13-2017 14:46
Best Answer11-15-2017 09:58
11-15-2017 09:58
They still can't work out why i cant sync it. Arghhhhh
Best Answer03-31-2018 12:30
03-31-2018 12:30
THANK YOU!
