08-16-2016 14:18
08-16-2016 14:18
What a mess! I used to use my FitBit Flex with the WeightWatchers Mobile app, and it was very useful and reliable. I just "re-joined" WW, and thought I'd use my new FitBit Charge HR with the WW Mobile. Well, all heck has broken loose since I last participated in WW.
My WW app and my FitBit are double and triple counting my FitPoints. For example, see the attached photo. I had 15,450 steps this day, including a 2 mile run, worth 7 FitPoints. Somehow, my WW app logged my 15,450 steps for 13 FitPoints TWICE, and in addition, it added 7 more FitPoints separately for my run, for a whopping total of 33 FitPoints for the day.
As far as I can figure, I should've gotten a TOTAL of 13 FitPoints for the day, right? Tried contacting WW, and predictably, they say it's a problem with the way my Charge HR handles logging activity. Help anyone?
08-18-2016 04:55
08-18-2016 04:55
Hi there @dmwierz, good to see you around. Note the API does not belong to us, so if there is an issue, its more hard to determine the source of it as we don't have access to Weight Watchers' data. Nonetheless I'd investigate this issue and we don't have reports of a glitch causing your points gets duplicate. At least from Fitbit's end.
My first recommendation is to revoke the access of WW to your Fitbit account and re-link the integration. To revoke the access you need to go to your Applications Settings. (I have left the link for a easy access from your end) Once you are here, look for WW and revoke the connection. When you have completed this step use @SilviaFitbit's post to reconnect your accounts.
Let try this and keep me posted how it goes, I'll be around if you need more help.
Best Answer11-29-2016 12:19
11-29-2016 12:19
01-01-2017 20:29
01-01-2017 20:29
Was this resolved? I am having the same issue. Not with the steps being recorded twice but with the steps being recorded and then a detected activity (that I did not enter like a run or walk) being recorded in addition to the steps earned for that same activity. I tried installing and uninstalling per WW support suggestion but that did not work.
02-16-2017 12:45
02-16-2017 12:45
Actually, you should have 7 activity pts. for your run and then points for your all-day steps, minus those steps taken during the run. So, if the run was 10,000 steps, you would get 7 pts. plus 5 pts (or 6 pts., depending on what #of steps puts you over 5pts.) for the remaining 5,450 steps you took the remainder of the day. Unless of course ALL your steps were taken during the run....
Mine is doing the same. It logs my full-day nsteps PLUS the workout I started in fitbit. It SHOULD log my workout points then subtract the steps I took during that workout time period and give me the remainder of the points/steps.
Fitbit used to do this very well.
03-06-2017 03:40
03-06-2017 03:40
I've just started using WW and noticed the same issue. For example, I've only been for a short dog walk this morning and 3 points for my 20 minute walk, then an additional 1 point for my 2601 steps. Did you find a way of working around this?
Thanks
03-21-2017 04:54 - edited 07-19-2017 04:07
Welcome aboard @jenfarley4, @radzieus and good to see you again @Pippop. Note that point conversion is not calculated from our end. Many of third party integrations are not developed by our initiative, but from the third party and is hard to access to this data. If you believe the point conversion for the activity on Fitbit is incorrect, make sure your steps are not being counted twice or there are duplicate entries on your exercise log.
If the tracker is recording your exercise correctly, revoke the access from Weight Watchers.
Also contact WW support.
See you around and thank you for bring this to my attention.
03-25-2017 20:51
03-25-2017 20:51
I am having this same issue only this week. What is the fix? It is important to get it fixed. Can't fitbit and weightwatchers talk to each other to fix the issue??
03-26-2017 18:51 - edited 03-26-2017 18:55
I started getting this issue as soon as I did the last Fitbit update. Now, when I sync WW app is adding Fitbit activity 3 times. Contacted WW support and got no where.
03-26-2017 21:12
03-26-2017 21:12
I started having the same problem yesterday. I now show all my Fitbit activities showing in triplicate each day since last Tuesday.
Very irritating.
04-05-2017 05:32
04-05-2017 05:32
I have this exact problem. Has anyone found a solution? Thanks.
Best Answer04-05-2017 05:39
04-05-2017 05:39
I just saw this post. I checked the date that the problem started for me and it was 3/26/17 which coincidentally is the same date as Fitbit did an update to their software... 🤔
04-07-2017 10:25
04-07-2017 10:25
I have been having the same issue so when I found this question today I followed RobertoFitbit's suggestion and it has worked. I chose "Revoke Access" on the Fitbit side and I chose "Disconnect" on the Weight Watchers side. Then on the Weight Watchers side I chose "Add a Device", then chose "Fitbit", and it took me to the Fitbit log in page and I logged in. The two then synced and now my WW FitPoints are now back to normal.
07-17-2017 17:17
07-17-2017 17:17
When you did this fix, did it decrease the points you'd already accumulated or did it take until the next day to start counting correctly?
Best Answer08-20-2017 15:13
08-20-2017 15:13
I've only just come across this problem as I'm new to Fitbit. I've found that there is an "auto-recognise" option that is responsible for this. If you go into exercise goals in your Fitbit account settings you will see a list of exercises that are auto-recognised. I've now turned that off for each individual exercise so I'm hoping that fixes it!
Best Answer09-16-2017 05:49
09-16-2017 05:49
@DebOD - this seems like it would be a good solution if you only want to have FitBit log steps to your WW Account - i.e. and ignore any exercise sessions. I'm not having an issue with WW double counting exercise from FitBit - but it does count my total steps and then will also count my morning treadmill run as an exercise session. I'd prefer to log both my total steps taken minus the steps I took on the treadmill and then count the treadmill run as a separate exercise. I don't think there is any workaround to do this. WW just tells you to take your FitBit off when you get on the treadmill (not helpful at all). It's been more work for me, but I ended up revoking access and I log my treadmill run separately. Then at the end of the day I'll enter my steps taken less the steps taken during the treadmill run. Too much work, but at least it accurately reflects the exercise I've done. If you have any other ideas, I'm all ears!! 🙂
09-16-2017 16:24
09-16-2017 16:24
Hi, thank you for your reply! I ended up changing settings so that the FB doesn't auto-count exercises such as walks etc. I think the defaults after an update meant that it counted any walk over 15 minutes as an activity/exercise. Once I turned off all of the auto selections we could all be friends again lol!
09-17-2017 09:18
09-17-2017 09:18
Great idea! 🙂
Best Answer10-03-2017 09:24
10-03-2017 09:24
Does this mean you have to enter all excercise activity manually to meet your execrcise goals?
Best Answer10-17-2017 19:48
10-17-2017 19:48
I’m having the same issue
