01-24-2015 19:31
01-24-2015 19:31
Withings scale is no longer updating my weight. I verified my Withings account is properly setup with Fitbit, however, when I attempt to downoad Withigns data (https://www.fitbit.com/weight/withings) I get the following error:
Best Answer01-25-2015 08:02
01-25-2015 08:02
I would ask over at Withings since the error seems to be generated from there.
Best Answer06-27-2018 19:10
06-27-2018 19:10
I was having this issue and discovered it was caused by manual entries I had put into Fitbit for weight. I deleted the manual entries from Fitbit and this error was resolved.
Hope that helps!
07-02-2018 05:36
07-02-2018 05:36
Hi there @AureliaCA,, good to see you here int he Fitbit Community one more time.
Thank you for your recommendation and your input on this error. I'm sure this will be super helpful for many users who might be in the same scenario.
See you around and stay awesome.
