03-17-2017 09:38
03-17-2017 09:38
Hello
i have the charge 2 and notice that when I log my workouts using the Fitbit it doesn't sync to MyFitnessPal. I have to manually enter them into MyFitnessPal but then it duplicates the workout on my Fitbit app
03-17-2017 14:23
03-17-2017 14:23
I have the same issue!!!! Who can help us?!? Lol
Best Answer03-18-2017 07:23
03-18-2017 07:23
Hello @birdee210, have a warm welcome to the Fitbit Community, it's great to have you on board. It's nice to see you around too @birdee210.
If your activities are not syncing correctly to MyFitnessPal, my suggestion would be resetting the connection between both apps so the information can be refreshed.
Please give it a shot and if your activities are still not syncing, please let me know! ![]()
Best Answer03-21-2017 14:24
03-21-2017 14:24
Mine is doing the same. I have refreshed the connection and it wont send the workout information to my fitness pal.....
Best Answer03-21-2017 19:57
03-21-2017 19:57
Hi,
I just bought the Charge 2 over the weekend and have noticed this same thing. MyFitnessPal syncs to Fitbit, but it doesn't work the other way around. So, I am not sure if I should be logging workouts into MyFitnessPal anymore. If I do, then it duplicates to the Fitbit app. Please help!
03-22-2017 05:24
03-22-2017 05:24
Hello @EmBp and @Smash0323, thanks for joining us, it's great to have you on board! ![]()
When resetting the connection between both apps, did you log out from both, MFP and Fitbit apps? This is very important for the apps to connect once again. You can also use the MFP site instead of the app in case the information is not updating and the apps are not syncing correctly.
To connect MFP and Fitbit through the MFP site:
Please try a couple of times to connect both apps and in case you need anything else, feel free to reply.
Best Answer07-09-2018 19:25
07-09-2018 19:25
Same issue between MFP and Fitbit. Completely logged out of both a reset the connections....wondering if my problem might be that I’m using both an iPhone and iPad to access my data in both apps. I notice the FB Charge 2 will only sync to the iPhone (not the iPad). Is there something I should do different if I am using two devices?
Best Answer10-22-2018 08:46
10-22-2018 08:46
Hi,
I’m having the same problem. I tried logging out and in again after disconnecting, but MFP keeps reconnecting instantly, even after disconnecting from both apps, and still only updates the steps, and not exercise. I want to upload my strength session earlier but it just won’t work.
Any tips?
thanks.
Best Answer10-26-2018 07:25
10-26-2018 07:25
Welcome to the Forums @anneliew.
Thanks for going through those steps before posting in here.
In this case I'd like to ask some questions to better understand the situation:
Look forward to your reply.
Best Answer10-27-2018 03:56
10-27-2018 03:56
10-28-2018 07:44
10-28-2018 07:44
Hello @anneliew.
Thanks for getting back to me.
In this case, only steps and calories tracked by Fitbit are synced over to MFP, that is the way the integration was developed. Please do keep in mind that this integration was developed by MFP so maybe you could get in touch with them to let them know that you'd like to see it be expanded to include other options.
Let me know if you have any further questions.
Best Answer10-31-2018 21:52
10-31-2018 21:52
I run into the same issue on the same device. It won't even sync steps. Though since the fitbit app tells me all that I need to do, I don't entirely think it has to go to MFP. The steps haven't really worked. I'm going to their forums next 🙂
Best Answer10-31-2018 21:59
10-31-2018 21:59
Actually, I take that back. I went to MFP on computer, went to Apps, then to Steps. Selected Fitbit and now it imported steps and calories, etc.
11-01-2018 10:51
11-01-2018 10:51
Hello @serenstar75.
Glad to read that everything is working correctly now.
If you have the time, maybe you could visit one of our Discussion boards. Lots of different topics to talk about with other users, maybe something will pique your interest.
Let me know if there are any further questions.
Best Answer11-01-2018 17:45
11-01-2018 17:45
Best Answer11-05-2018 07:58
11-05-2018 07:58
Hello @KaseyD3.
Thanks for sharing your feedback. Please do know that we are always looking for ways to improve the overall Fitbit experience and we take comments like this very seriously.
Feel free to reach out with you have any questions.
Best Answer11-07-2018 22:23
11-07-2018 22:23
I found solution to not having the calorie adjustment in myfitnesspal or double-workouts in Fitbit. I didn't want a calorie adjustment in myfitnesspal unless I actually did a workout. Fitbit seems to adjust your calories allowed if you have a high step day but don't actually do a workout. This might work for some, but I only wanted the extra calories if I earned them! Here's what I did:
Myfitnesspal and Fitbit accounts are linked, but in the myfitnesspal app I went to more --> steps, and selected "Don't track steps". This stopped the calorie adjustment in myfitnesspal.
I use the Fitbit to track the time I started and stopped working out. When I enter my workout into myfitnesspal, I choose the activity and enter the start time and length of workout from the Fitbit app into myfitnesspal. When they sync, the workout I entered in myfitnesspal now shows up in Fitbit and I delete the original (the information will be exactly the same if you match the time).
It's only a couple extra steps and solved my problem - hope this helps!
Best Answer11-08-2018 07:15
11-08-2018 07:15
Welcome to the Forums @gcasselman.
Thank you very much for taking the time to share all of those steps with everyone! I'm glad that you found a way to get it to work in the best way for you. Hopefully other users will give it a shot and find it very useful.
If you have the time, maybe you could visit one of our Discussion boards. Lots of different topics to talk about with other users.
Feel free to reach out if you need any assistance.
Best Answer04-30-2019 07:05
04-30-2019 07:05
That isn’t a solution at all.
He’s having to manually input and then bypass the Fitbit app.
Why doesn’t it just sync. I have the same problem that as I have an active job my “step count” is massively wrong but I want my workouts to sync.
I have done all all of the steps you’ve said previously with no success.
04-30-2019 07:46 - edited 04-30-2019 07:46
Welcome to the Forums @olfrench.
Thanks for trying all of the steps that have been recommended.
In this case I'd like to ask if the situation has continued since then. I'd also like to ask you what specifically is it that is going on? Is it that the information is not syncing over to MFP? If so, what information is not syncing? Or what information is syncing?
I look forward to your reply.
