11-04-2018 05:23
11-04-2018 05:23
Has anyone upgraded to iTrackbites Pro so they can sync their fibit with the app?
Best Answer01-03-2019 11:28
01-03-2019 11:28
I have iTrackBites Pro, and all it syncs from Fitbit is your step count.
11-05-2018 06:08
11-05-2018 06:08
Hello @SunsetRunner.
Let me help you to connect your Fitbit app to iTrackbites Pro.
According to their support page, you have to follow these steps:
That should do the trick. You can click here to read that help article from iTrackbites.
Let me know if there are any further questions.
11-05-2018 08:19
11-05-2018 08:19
I was just curious if it was worth the upgrade actually but thank you! Like does it sync sleep, food, workouts...
Best Answer11-06-2018 05:23
11-06-2018 05:23
Hello @SunsetRunner3.
Thanks for the clarification.
I'm afraid I wouldn't be able to answer that question given that these integrations are developed by the third parties themselves. Maybe you could try getting in touch with iTrackbites and ask them about it.
11-07-2018 02:48
11-07-2018 02:48
I tried, you need to be a Pro member to post in the forums there...![]()
Best Answer11-08-2018 07:01
11-08-2018 07:01
Thanks for giving it a shot.
There has to be another way to get in touch with them. Maybe through Facebook or Twitter? Unfortunately asking them directly is the only way to move forward in this case.
Let me know if there are any other questions I can help you with.
01-03-2019 11:28
01-03-2019 11:28
01-30-2019 18:37
01-30-2019 18:37
I have iTrackBites Pro and have been unsuccessful following the syncing steps. I have uninstalled and reinstalled both apps several times. When I click on the connecting button to link to Fitbit, the next screen where you allow the integration, I click allow and nothing happens. Is there anything else I can do?
02-01-2019 10:16
02-01-2019 10:16
Welcome to the Forums @Stephanie.krah.
Thanks for listing all of the steps that you have already tried.
In this case I'd recommend that you try to get in touch with iTrackBites Pro directly given that these integrations are usually developed by the third parties and thus they should be able to take a closer look at what is going on.
Let me know if you have any further questions.
Best Answer02-02-2019 07:05
02-02-2019 07:05
02-04-2019 08:32
02-04-2019 08:32
Hello @Stephanie.krah.
Thanks for letting me know.
In that case maybe you could post about it in our Feature Suggestions board. Lots of other users could then comment and vote on the idea to show their support. Be sure to read the FAQ to better understand how that board works.
Best Answer10-23-2019 08:28
10-23-2019 08:28
It won't let me connect.
11-04-2019 21:11
11-04-2019 21:11
same, I've tried numerous times with no luck. emailed with no response.
