12-11-2013 16:50
12-11-2013 16:50
Loving my FitBit but one thing I'm having challenges with is connecting MyFitnessPal caloric intake data with Fitbit. I like using the MFP screen cap of UPC codes feature - but can't figure out why it wont transfer the data over to Fitbit.
Any ideas?
Best Answer12-11-2013 17:34
12-11-2013 17:34
Did you link the two accounts? If not, then go to the MFP site, then click on the apps tab. Scroll down until you find FitBit and click on that. On the FitBit page at the right you will see a button to buy and then below it in small print is a link to connect the accounts. Don't click on the button but on the connect link. Follow instructions and the two accounts should link.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
12-11-2013 17:34
12-11-2013 17:34
12-11-2013 21:45
12-11-2013 21:45
thanks! it worked!
Best Answer01-11-2014 20:02
01-11-2014 20:02
Mo account is synced according to both fitbit and my fitness pal, but my food and activities are not showing up in my fit bit dashboard ??
Best Answer01-16-2014 16:56
01-16-2014 16:56
01-17-2014 10:19
01-22-2014 21:33
01-22-2014 21:33
I am having the same issue. MFP shows my fitbit activity adjustment but the fitbit dash or app does not show any info on food or calories, i.e. says I still can eat a full day's worth of food. On a similar theme, my digifit dash shows my fitbit info but again my fitbit shows nothing. Anyone have a fix?
Best Answer02-23-2014 13:42
02-23-2014 13:42
Hi
Does any one know where MFP get the calories burned for the fitbit ajustment calories and how it works?
04-01-2014 18:29
04-01-2014 18:29
I think it's the differnce between the calories your body automatically burns and the calories you actually burn. So if you workout your calories burned will be higher and MFP will give you this as additional calories in their calculations. They show up on the bottom of the page on MFP.
10-06-2014 21:28
10-06-2014 21:28
i was wondering do i chart on fitbit page my food or my fitness pal i have been using my fitness pal but now that i have the fitbit one i was wondering how that works, thanks
Best Answer10-06-2014 21:46
10-06-2014 21:46
10-06-2014 21:49
10-06-2014 21:49
thank you so much, it does not look like it is transferring anything but i will keep trying
Best Answer10-06-2014 22:06
10-06-2014 22:06
Best Answer10-07-2014 19:48
10-07-2014 19:48
its working now thanks
Best Answer01-06-2015 23:05
01-06-2015 23:05
Thanks for this info, I was struggling getting the two accounts to link but now very happy!!
Best Answer01-12-2015 10:04
01-12-2015 10:04
